Question about Fisher and Paykel WA37T26G Top Load Washer
Fisher and paykel eco smart washer model number WA37T6G error code 31? I ran a test on my washer and it came up with error code 31. I have only found error code 37 online. It will put water in when I do a test but otherwise it won't run and when you put it on spin it makes a low humming noise.
Posted by Gwen Kozak on
Greg Stephen
  • Fisher and P... Expert
  • 566 Answers
There is no code for 31.
To work out your fault code just add up the lights that are on.
Fisher and paykel eco smart washer model number - ede190e0-841d-44bd-aa94-bda2174b651c.jpg
Posted on Dec 17, 2013
5 Related Answers
Tony Coultrip
  • 183 Answers
SOURCE: fisher & paykel GWL08 washer
faulty pcb Regards Advisor
Posted on Aug 22, 2007
Anonymous
  • 92 Answers
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Posted on Feb 22, 2008
l blight
  • 28 Answers
SOURCE: my fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Posted on Jul 03, 2008
Anonymous
  • 639 Answers
SOURCE: fisher and paykel intuitive error code 37
Dear chopper667,
ngfam1 here for you!
I am happy to be of assistance!
Try unplugging the washer and then rebooting it after 3 minutes!
If this fails,
here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
Posted on Aug 26, 2008
Joe LaFayette
  • 13 Answers
SOURCE: Too many suds
Error #37 is a pump blocked error. Says that machine has not drained out. Check that the pump is not blocked (by removing the top, agitator and basket) or that the drain outlet is not too high. ( maximum height for drain outlet is 7'). If you do end up throwing the thing out, I'll give you something for the motor controller circuit board as I think mine is faulty.
Posted on May 29, 2009
What is a Fisher and paykel eco washer error 59
http://ww2.justanswer.com/uploads/thehomesmithy/2010-12-19_141627_gwl11_iwl12_iwl15_suppliment_togwl03_manual_.pdf
here is the manual
it has detailed info on your error code
96 decimal is 01100000 binary
so look for that.. youll see what i mean when you look at the manual
i think its a phase 6 error
and looks like something to do with the pump
Feb 07, 2015 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel error code 37
check drain pump is not blocked or faulty
Aug 03, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 49 f&p aqua smart wl80t65c
49 is a cold water valve fault. test the valve for voltage while filling, it should be recieving 24V. if not, the problem lies with the motor controller.
Aug 30, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Code 43
Error Code 43 means OUT OF BALANCE SWITCH FAULT.Is your model an ECO smart model?Have you or can you borrow an electrical test meter to test the OUT OF BALANCE SWITCH?Please reply with additional information and I am sure I can help you rectify this fault.
Jul 22, 2010 | Fisher and Paykel WL37T26DW1 Top Load...
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Error codes
We have an instruction manual but there are no codes.
Apr 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel WA37T26G Top Load Washer Logo
263 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Michael Thomas
Michael Thomas
peter gittos
peter gittos
Marvin
Marvin
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
