Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error Code 4 on Saeco Talea Ring
Can anyone tell me what Error Code 4 means on a Saeco Talea Ring? The unit makes a soft beep 4 times before displaying the error code. I have tried removing all of the components (brewing group etc), but the error keeps re-appearing.
  • c_r_procter Jul 27, 2009
    It ended up back with the manufacturer. The problem was a stuck motor I believe (the one that moves the brew group into position). Immediately after speaking to customer care they knew what it was and said it had to go back in. They replaced the motor. Sorry there isn't an easier fix.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5083
Points
10
I need to know what error code 4 means as well.
Has anyone helped you yet?
Anonymous
Level 1:
New Friend:
  • Posted on Feb 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5083
Points
I have error code 1 does anyone know what that is
Anonymous
Level 2:
Sniper:
  • Expert 81 Answers
  • Posted on Mar 06, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
81
Questions
0
Helped
87378
Points
240
Error code 1 means the grinder is not working, either the motor is bad or there is no power supply to the motor.Have to take it back to the Seaco service center.
  • Love to fix Jul 17, 2011
    I just took out my grinder and cleaned it due to error code 1. I removed it with instruction from another post in Fix-ya. It was tricky getting the cover off and really pops off. The sensor is magnetic and on the bottom gear of the grinder are two little magnets on opposite sides of the gear wheel. I discovered after reassembly that the magnet has to be aligned up with the sensor for the grinder to startup. If Clogged, there probably is too much friction which throws the alignment off. I suppose you could try to turn the grinder to coarse and then use a 10mm socket to turn the grinder in increments to find startup position again and then try to use an allen key to reach down the pre-ground feed hole and clear out the grinder outlet. Beware there is a metal flap that is in there at a 45 degree angle that acts as a baffle that you will need to reach under. try using a dental mirror. Personally' I'm glad I took my grinder out as I know how to do it now and was able to clean it better. Note that the grinder seems to be a one piece design after the motor is removed. I was told by Saeco that some beans have little pebbles in them and can get clogged in the grinder. Another post from a dealer blames oily beans. I'm thinking it is oily beans and this may happen to me again. I've had my unit 1.5 years.
  • Anonymous Sep 08, 2012
    Can you tell me where you found the instructions to clean the grinder on fixya? Thanks!
11helpful
6helpful
On my talea ring plus i get an error code 5. anybody knows what that is?
Error 5 is the water circuit is block, or airlock in the system that means you have to purge the air out.
4helpful
Out of service [4] out of service [87] restart to solve the problem SAECO TALEA RING PLUS
Hi...itis not self testing..in otherword the motor in the gearbox is not working, either itis jammed with rust cuz' of leakage or motor is bad.
2answers
Saeco Talea Ring Plus: often, water flows out of of water steam
The valve parts need to be replaced, if it is only happening when brewing coffee then there is so much pressure on the pump that it is forcing the valve open. First try adjusting the amount of coffee be added to the chamber for brewing.
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
4helpful
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
1helpful
HOW DO I GET THE INSTRUCTION MANUEL FOR A SAECO TALEA RING PLUS COFFE MACHINE?????
The French Saeco website has manuals (in English as well as French).
Try this url…
http://www.saeco.fr/en/manuali/manuali.html
HTH
1helpful
Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
5helpful
The selction ring on the Talea Ring Plus doesn't work anymore, does anyone have a clue?
I had the same problem, after dismantling the machine I found that the touch detector is glued to the back of the plastic front panel and had become detached, so that it was too far from the operator's finger to work. Reattached with fresh glue, checked connection to main board, works perfectly now.
3answers
Water from steam nozzle
I purchased a Talea Ring in February this year and have exactly the same problem
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
