Hello ,
These all in one systems are similar to laptops because they use a laptop charger.and a laptop power adapter connection. Make sure to see if any lights light up to show if the system is receiving power.. If not then its either the dc connector that is on the system board. If your quite technical I always remove all components like the memory sticks,hard drive and dvd drive, then power the system back on just to make sure its the system board is not be shorted out.I like to rule all that out . Those system boards are not cheap. If your not that savy then just have a tech check it out.
SOURCE: my inspiron one 2305 won't
The connection on your laptop may be damaged ,Try wriggling it GENTLY when plugged in ,.
It really looks like you need a new power adapter if that does not work.
A pc shop or electrician can also test it for you.
Try your friends for same power adapter to test it .
After that its ebay or pc shop
SOURCE: dell inspiron one 2305 power supply short
This is due to a bad cable and/or LCD Inverter board. I would replace both. Had this problem before and it's definitely the pointing at the LCD Inverter and it's connectivity to the motherboard. Dont just by the board, get both board and cable, US$35 on Ebay.
