Evesham Voyager 6200 Notebook Logo
Posted on Apr 05, 2009
Evesham System Recovery
Hello,I have an Evesham MH 47 (x86) laptop and would like to restore it to factory settings. The performance has slown down and it is getting very hot underneath. I am aware that this could be the hardware going, but would like to try to restore the software / system.I have a recovery disk for XP? But do not know how to recover the computer back to factory settings? (wiping my docs etc..)Any help anyway can provide will be much apreciated!
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 05, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3023
Points
12
Simply enter the recovery disk and follow the instructions for "remastering" this will returrn your pc to factory settings
How do I reset my Toshiba Satellite 1800-S207 laptop to original factory settings
Satellite 1800-S207
Windows 7 and earlier Toshiba laptops come with the factory software recovery image stored in a special (hidden) area on the hard disk. From this special hidden image, you can restore your computer to its factory-fresh software condition.
How To: Perform system recovery - Windows 7
The following article will show you how to perform a system recovery. To Recover or perform a system recovery means to take the laptop back to factory settings (default settings). System restore means to go back to an earlier point in time on the computer.
There are two methods to perform a system recovery:
  • Using Partitioned Recovery Method (Free Recovery)
  • Using Recovery CDs / DVDs / Media
Details provided at the link listed below.
http://forums.toshiba.com/t5/System-Recovery-and-Recovery/How-To-Perform-system-recovery-Windows-7/ta-p/279643
Restore means to go back to an earlier point in time on the computer.
Refresh means PC settings will be set to default without effecting personal files or settings.
Reset means back to factory settings. (default settings) - deleting all personal files, programs and settings. Similar to Recover or Recovery
Windows 8 Toshiba laptops have many restore and recovery options available depending on your needs. To better understand these options and how they affect your computer, please view the video available in the linked article below.
http://forums.toshiba.com/t5/System-Recovery-and-Recovery/How-To-Understanding-System-Restore-Refresh-Reset-and-Recovery/ta-p/342690
Restore hp pavilion dv7 1464nr to factory settings windows
Step 1:
Which operating system ?
Restore Hp laptop factory settings without a Restore Disc Turn on the HP laptop. When the blue HP screen appears, press the "F10" key repeatedly until the "Recovery Menu" appears. A progress indicator informs you of the time before the recovery process is to take place. Click "Next" in the Recovery Menu. Decide whether you want to perform a nondestructive or destructive recovery. A "nondestructive recovery" does not format the laptop's hard drive or erase any personal files on your laptop. However, a "destructive recovery" formats your laptop's hard drive and erases any personal files you have on your laptop. Click "Yes" to execute a "Normal, nondestructive recovery." The restore process begins and your laptop restarts. Alternatively, to execute a destructive recovery, click "Advanced." Click "Yes" to start the "Destructive recovery." The restore process begins and your laptop restarts.
Restoring with CDs Back up all crucial user files if you are able to do so. If your computer will not burn CDs, use flash drives of 4GB or higher to store your data. Alternatively, you can use your network to transfer files. You can then back up your data to CDs at your leisure. Detach peripheral devices such as removable media drives, USB drives and your printer before recovering. Also remove any additional hard drives by disconnecting the cable from the back of the computer. Leave your monitor, mouse and keyboard attached to the computer. Shut down your computer. Place the first recovery CD in the CD drive. If your recovery files are written on a partition, you may be able to select system recovery from the splash screen and your computer starts. Select the recovery option you would like to use. To perform a destructive recovery, click the "Advanced" menu option. Select "Destructive Recovery" and click "Next." To perform a non-destructive, or system, recovery, click "Next" from the opening screen. Watch the computer while it is recovering to the factory settings. Watch for any errors, as the computer will wait indefinitely for a response from you, slowing down recovery time. Also, you may need to insert additional recovery CDs as the recovery program requests them. b> Restoring With Recovery Manager Click the Windows "Start" menu, type "Recovery" in the Search field and press "Enter." Click "Advanced Options," choose "System Recovery" and select "Next." If you are prompted to use Microsoft's recovery program, select "No." Choose the option to back up your files, if you haven't done it already. Once that is complete, choose "Next" to begin reformatting the drive and returning the system to factory settings.
RESET TO FACTORY SETTINGS
What type of Laptop ? and operating system on it ?
Restoring your laptop to factory settings can take up to an hour to perform, depending upon the type of laptop and operating system on your machine. Prior to performing a system recovery, you should remove any external peripherals, such as ExpressCards, PC Cards, and USB-connected printers and hard drives. Turn on the laptop. Press the "F8" key until the "Advanced Boot Options" screen appears. Select "Repair Your Computer" using the arrow keys. Press the "Enter" key. Choose your "Language," then "Next." Login with an administrator-level username and password. Click "OK. Select "Dell Factory Image Restore," then "Next." Tick the check box next to "Yes, reformat hard drive and restore system software to factory condition." Click "Next." Click on "Finish" after the computer has concluded the factory restoration. b> Restore on an HP b> Insert the HP recovery disk. Restart the computer, and press the "F11" key. Press the "F" key to "reinstall factory settings." If your computer's operating system is damaged, you may only see "perform a full system recovery" as an option. In this case, press "R." Insert any disks if prompted by the restoration program. Otherwise, permit the computer to restart as needed. b> Restore Via Disks (Generic) b> Insert the "Recovery Disk" or "System Recovery Disk." If you have more than one disk, make sure you insert "Disk 1" or "Part 1." Press any key to boot from CD if prompted to do so. Choose a "Full System Restore," "Restore Factory Settings," or another option worded similarly. Confirm that you want to perform the restoration. Press "Next," "Yes," or "OK," as needed. Press "Finish" or "Restart" when prompted by the computer. Hope this helps.
Will not start
A brand name and model with operating system would be nice so someone could be precise. ?
6helpful
2answers
How to do full system recovery for my sony vaio PCG-4JBP? thk u
Not sure what you mean when you say "full system recovery" but the operating system will have system restore points that you can access from the control panels system protection option. If you want to perform a factory default reset, start up the laptop and then look out for options that can be accessed by pressing one of the number function (Fn) keys. I believe the Vaio range comes with an option to restore the laptop back to it's shipped factory defaults, the interface is reliable and did a great job when I restored a Vaio VGN-NW20EF, came out like new!
6helpful
I want to restore my acer aspire 5741 to factory settings but when i go to restore it, a message comes up saying hard drive configuration is not set to the factory default. reboot aborted.
Before performing a restore operation, please check the BIOS settings. To activate the BIOS utility, press F2 during post.
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process.
3. Refer to onsreen instructions to perform system recovery.
Follow this steps.
Thank you for using FixYa.com
3helpful
2answers
How can i restore my laptop to factory settings
Most of the HP Notebooks are shipped with recovery partitiona d you can restore to factory settings uisng teh recovery partition.
Perform ing Full System Reocvery will completely remove the data on the hard drive. Hence it is recommended to take the back up of the important data present in the Notebook before perform ing the Full System Recovery.
1. Restart the notebook.
2. At the Compaq logo, press F11 to initiate the Recovery options.
3. The PC Recovery screen will be displayed. Select PC Recovery and
press Next.
4. In the next screen, click OK to access the Recovery menu.
5. You will receive a screen explaining the System Recovery Process.
Click Next to continue.
6. Once the Recovery process is completed, you will prompted to either
restart or turn off the computer.
How to restore factory recovery system
If you still can boot it in windows, follow this:
Step 1: Click “Start” menu.
Step 2: Click “Programs.”
Step 3: Click “Acer Recovery Management.”
Step 4: Click the “Restore” button on the bottom of the dialog box that opens.
Step 5: Click “Restore System to Factory Default.”
Step 6: Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
Step 7: Click “Start” to restore the computer to the default factory settings.
If you can not boot to windows, follow this:
1. Restart the laptop
3. Follow the on-screen instructions to perform system recovery
Cant access control panel or system restore. And if i get to the screen and click on file the desktop icon disappear
The issue can be due to virus in the system. I suggest you to scan your system completely and if any virus is found, remove it. Check if you are able to access Control Panel or System Restore after that.
You can perform Norton online scan from the below link:
http://security.symantec.com/sscv6/WelcomePage.asp
If the above steps do not resolve the issue, perform System Recovery.
Before performing System Recovery, backup your data as recovery will completely erase the data and will restore the notebook to factory settings.
Visit the below link for information on System Recovery:
http://notebook-solutions.blogspot.com/2009/06/performing-system-recovery-in-vista.html
Select Acer Recovery and perform System Recovery.
How can i restore my evesham laptop back to factory settings
Go to evesham homepage (http://www.evesham.com/), and tell them you problem, they will tell you what to do to restore the laptop.
Top Evesham Computers & Internet Experts
Alexander
ADMIN Eric
ADMIN Eric
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
