Question about Archos TV Plus, 80GB 80 GB Hard Drive
Archos 605 160gb keeps switching off
When connected to the TV dock have problems accessing folders as screen freezes and sometimes get a screen filled with vertical black and white stripes.
When not connected to dock it will sometimes switch completely off and can then only "reactivate" by placing back into dock.
Anonymous
I save all my data to an external hard drive, restored factory settings and then transfered my data back to the Archos. It seems to be working OK now.
Before anyone else tries this they need to make sure that they have the access codes for any plud ins that they've purchased.
Posted on Apr 06, 2009
Stuck on the ARCHOS Screen and it won't do any thing
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jul 24, 2009 | Archos 704 WiFi Digital Media Player
Archos 605wifi not switching on
Hi, my Archos 605 160GB is doing the same, Sorry to say the battery has gone.
2 options
1. Back to Archos
2. Replace the battery yourself I ordered mine from HK from the web site BatteryUpgrade. co. uk for about £24 - If you search on Utube there is a video showing you how to change the battery on smaller 605's
Jan 09, 2009 | Archos 605 WiFi Digital Media Player
Archos 605 wifi freezes
Mine kept freezing alot, and now the on/off button wont work. I can only turn it on with the docking station.
Jun 14, 2008 | Archos 605 WiFi Digital Media Player
ARCHOS 605 WIFI FIRMWARE DISABLED
hitesh_rao - the reset button is at the bottom by the USB and docking ports. Tiny hole, need a pin or paper clip. Once pressed, just switch it back on.
This may be a stupid question, but when trying to configure the TV IR controller function and entering the relevant codes for my TV's, it asks 'did the TV switch off = Yes/No?'
None of my TV's switch off and then I cannot go any further with the config. Is this right? I have logged this with Archos FOUR times now, and they just respond with 'the controller does not control your TV'. I am fully aware that it is not a TV controller, but then why does it want to switch off my TV during the config? I just want them to answer that question.
Somebody please help!
May 22, 2008 | Archos 605 WiFi Digital Media Player
I have an Archos 605 WiFi. I haven't yet connected my Archos docking station to the TV and HDD. Meanwhile, I thought I would copy a programme from the HDD to a DVD, then put the DVD in the computer and...
What kind of HDD do you have, do you have any type of output on it. You stated that you haven't connected the docking station to it and the TV...? The best thing to do is to connect your Archos to the Docking station. Set the docking station up correctly, with cables coming out of the HDD (if it has some sort of output) to the station and out of the station to your TV. Once you set that up, you can use the Archos as a mini DVR or VCR. Go to the REC option on the main screen of Archos, you'll have an option for Video Recorder (tab on top). If you play any source on the HDD, then all you have to do is press the Rec option on the Archos. If you already have a file on the HDD, then try just moving it over into the Archos once you connect the Docking station to your computer via USB or just use the USB cable connected to the computer with the HDD. I use the USB preference as Windows Media Device. (found under menu/settings/system). Is is basically a HDD itself. Remember the Archos will only play certain videos without the purchase of any extra plugins.
Good Luck
Apr 14, 2008 | Archos 605 WiFi Digital Media Player
Connecting to a tv
YOU NEED TO GO TO SETTINGS ANDCHANGE THE PLAY MODE TO PAL FORMAT
Feb 11, 2008 | Archos 605 WiFi Digital Media Player
How do I get my Archos to work ont
if you are using an Archos cable, when you plug in to the tv, you should switch to the video 1 or line in source, probably using your tv remote labeled "input"
Dec 05, 2007 | Archos 504 500870 Digital Media Player
Archos 604 dvr blank screen
It sounds to me like there's an Component A/V cable issue. Please re-check the cable connections making sure they are connected correctly. When using the docking station and Component A/V cables you must be sure the cables are connected with their corresponding colors on the back of the DVR Docking Station. Also check that the format of the recording is compatible with the "TV Standard" in the settings menu of your Archos. It will be either NTSC (USA) or PAL (Europe). Be sure to check the Video Output Settings of the Archos to be sure it is set to the same type of cables you are using- component, RGB, s-video or composite. Good luck!
Sep 13, 2007 | Archos 604 Digital Media Player
Archos TV Plus, 80GB 80 GB Hard Drive Logo
210 people viewed this question
Top Archos Computers & Internet Experts
Lawrence Oravetz
Barbat Nae
Barbat Nae
Andrew Taylor
Andrew Taylor
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
