HAVE NOKIA N73 HAVE PROBLEM ALWAYAS SLOW CHARGING BATTERY I M CHARG BATTERY FEW MINT FINESH CHARG HAVE NOKIA N73 HAVE PROBLEM ALWAYAS SLOW CHARGING BATTERY I M CHARG BATTERY FEW MINT FINESH CHARGHAVE NOKIA N73 HAVE PROBLEM ALWAYAS SLOW CHARGING BATTERY I M CHARG BATTERY FEW MINT FINESH CHARG
You can't post conmments that contain an email address.
Change your battery charger, it should work,.... please anyone, how to unlock my master reset code. my handphone is N73 ME and my imei is 358973011580244
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle. There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A) Hope this will give you some ideas of where to poke. Once successful, please post your solution.
as i know sure its also some times show the battery full and after switch off by him self or after few seconds tell it very low .so just buy new origin battery and dont charg it until became low to save it for long time
The Nokia N73 is a pretty old mobile phone for now. Solution : Firstly check the battery of your phone. Try replacing it with an other battery model BP-6M. If Problems solves, buy a New Battery(Model: BP-6M).
its very easy dont install any antivirus for your mobile just install kasper sky net in your pc and scan the memory card the problem will be solved........
