SOURCE: canon zr200 cassette loading
reading other threads here the soloution that works, yes for real, slap it on the tape side (closed) a few times then try to reload the tape, if it doesn't work the first time, close it and try slaping a few more times. I had to do it a few times but it does work.
SOURCE: Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
SOURCE: will not accept cassette - keeps responding "eject cassette"
Had the same problem and took the battery out of the camera to reset. Worked fine after that.
Top
Paper jams inside the printer
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
