2001 Chrysler Voyager Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Van Wont Start Then Start's
Took the van to the shop and had timeing belt replaced and crank cap and spark plugs took it out all day long then came home and the next day it wouldnt start then couple of hours later it started
Colin Stickland
Level 3:
  • Chrysler Master 22,516 Answers
  • Posted on Apr 05, 2009
Colin Stickland
Chrysler Master
Level 3:
Answers
22516
Questions
Helped
6998108
Points
66324
Please explain what you are calling a crank cap?? is it the magnetic pick up sensor on the flywheel if so either clean the connections in the multiplug or try putting the old one back on
Engine cranks fast and wont start when cold.
clean the battery cables or tighten them.
Cranks but wont start
Engines need three things to run. Air, Fuel, and Spark. If you can verify the air cleaner is clear, and fuel is available at the carb, then the ignition timing must be the issue. Check to see if the distributor, and cap that you installed, are still tight. Check for spark by removing one spark plug boot, insert one of your old spark plugs, and have someone crank the engine for you to see if you have spark. Air, Fuel, and Spark, its one of this three.
My 94 gmc safari van wont crank until i clean the soot off the plugs then runs 10 minutes dies wont crank until i clean soot off plugs it wont stay running whats wrong?
just a guess but check if you have the right spark plugs for you van. spark plugs have a heat range. the right plugs for your van are AC R 43TS If you have a V6 engine. Also check your plug wires or just replace them. I would also check distributor cap and rotor. these parts are inexpensive, I would just replace them and see if that fixes the problem. if you did this already I don't know what to tell you know I will research my owners manual if I find something else I will pass info to you.
2answers
Can you test the ignition control module? i have a 1988 chevy g20 van w/5.7 motor it sat for a long time . it ran good and then one day it would start i put in a new fuel pump,fuel filter,coil,plugs,dist...
ADVANCE AUTO HAS A MACHINE TO TEST MODULES.. BUT IF I WENT THROUGH THE HASSTLE TO REMOVE IT I WOULD REPLACE IT..YOU ARE DOING WHAT IS CALLED SHOTGUN REPAIR..REPLACING PARTS ON A GUESS..NEED TO FIND OUT WHAT YOU ARE MISSING SPARK,,, FUEL,, COMPRESION...GET BACK WITH ME
2helpful
2answers
My dodge ram van wont start no spark replace many parts
i know alot of crysler/dodges had a crank sensor i had 1 go out on mine check see if you got 1 chances are thats it when mine went out it would turn over but no spark
3helpful
Sporattic engine stalling- 98' Chevy Van 5.7 liter automatic.
vacuum leak at throttlebody,check dist.cap wires, bad spark plugs also check vacuum hoses
2answers
Engine Cranks But Will Not Start
For an engine to run, you need three things to happen inside the engine. Compression, fuel and ignition, without any one of these components the engine will not run.
Basic Checks:
A. Test Fuses. Test both under hood power distribution center and the fuse panel under dash. This is done with a test light tool. The test light should illuminate on both sides of the fuse, if not the fuse has failed and needs to be replaced.
B. Testing Fuel Pressure Test for proper fuel pressure with a test gauge on the fuel rail, most throttle body injection cars (TBI) are between 13 psi and 17 psi. and most (DPI) direct port inject systems are between 40 psi and 55 psi. If no or little fuel pressure is observed and there is 12 volt power present the fuel pump, the fuel pump needs replacing.
C. Checking Timing Belt Test for compression by removing a spark plug and insert a compression gauge. Crank the engine over about 5 seconds the gauge should read between 125 psi and 165 psi, if no compression is observed remove front engine cover to inspect timing belt or chain. Crank engine to observe cam rotation, if the cam does not rotate the timing belt or chain has failed. (note: if the timing belt drives the water pump it is best to replace the water pump at this time)
D. Test for Injector Pulse Remove injector connector to insert injector test light (node) or volt meter. Observe light flash or gauge pulse while cranking. If light/voltmeter doesn't respond, an ignition distributor/crank angle sensor (CKS) or an ignition module is most likely your problem.
E. Test for Ignition Spark Remove spark plug wire, insert an extra spark plug into end of wire, rest spark plug next to a ground source then crank engine. You should observe a blue spark between the spark plug gap and ground source. If no spark is observed, an ignition coil, ignition rotor or spark plug wires might have failed. (always keep hands away from engine when cranking)
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
