Acer Aspire 9300 Notebook Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Acer 9300 black screen at start, tried some things, didn't work.
I have tried the external moniter, with no luck. i got it from a friend and they /they had put, a new screen in. when you try to start it the green light goes on around the power and the screen goes a very slight lighter color of black, but no picture. could be screen installed wrong, would really like some wisdom on how to fix laptop!! THANK YOU!
  • 2 more comments
  • bobcat915 Apr 05, 2009
    yea i tried the "Fn + key" but i did not restart after, ill try that and pray for the best!
  • bobcat915 Apr 18, 2009
    well i tried to do the reboot after haveing the vga external moniter in, but to no avail. would a totally bad cmos battery be the culprit?
  • Anonymous May 05, 2009
    i got the exact same problem, please help
  • Anonymous May 11, 2010
    Did you check the "Fn + key" to make sure you have selected the external monitor and then rebooted the computer? In order for the laptop to recognize the new monitor it has to be installed and configured. Usually a reboot with it connected will do the trick. You may also have to play with the Fn keys to select the alternative video source. Hope this helps!
    OpenSource13
JDTec
Level 3:
  • Acer Master 4,338 Answers
  • Posted on Apr 15, 2009
JDTec
Acer Master
Level 3:
Answers
4338
Questions
0
Helped
2127014
Points
14653
The cables to the LCD and the Inverter board may not be hooked up correctly...
I have manual, I can email it to you. [email protected]
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
  • JDTec
    JDTec Apr 16, 2009
    I sent the manual via email. I put it on this site.If you did not receive it, download it from here:
    http://www.yousendit.com/download/dVlwck...
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Anonymous
Level 2:
Scholar:
  • Expert 62 Answers
  • Posted on Apr 19, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
62
Questions
0
Helped
27623
Points
212
Bobcat915,
I have encountered this situation before myself and it was due to the frequency range and resolution that the external VGA monitor can handle. First, try dumping down your screen resolution to an 800x600 on the laptop itself. Save the setting and reboot to make sure it stays. Next connect the external monitor and reboot the system with it plugged in (power and data). See if the monitor will display anything. Note: You may also have to look at the frequency setting of your video card in the laptop in order to match it with your external monitor.
I can't imagine that a bad CMOS battery would be the issue. Does the screen on your laptop work without the external monitor plugged in?
Acer Aspire 9300 1 long and 2 short beeps
Have the same problem and i solved it after 1 month tries
the problem was in NVIDIA Graphic card
the solution was by by heating the NVIDIA Graphic card for 5 min or more
2helpful
Acer Aspire 9300. Symptoms:Powering up, the HDD light flashes twice but that's all. Have tried replacing Mobo. No change. Have replaced CPU. No change. Have tried removing both HDD and the two RAM cards....
Did you change the HDD ?
Did you change the MOBO?
Please try to change the battery or charge the battery again or can check by your nearest technician.
If there is any courser blinking any on the screen think your LCD is ok.
The HDD is defected.
If there is no courser ,The hdd is spinning thing LCD could be damaged,
Hope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
My Acer Aspire 9300 isn't starting any more, all I see is a black screen and the 2 lights in front and te power button are on. You hear the dvd-writer spinning but the screen stays black. I allready tested...
You can try to connect it to an external monitor using the vga connector on the side of the laptop.
greed03_3.png If that works, try and hold down the function button and press the F8 key. That should switch between the two screens. If the Laptop screen still does not come on, It is probably bad.
Hope this helps!
1helpful
Acer Aspire 9300 My Aspire 9300 has worked fine
It maybe the problem of your graphics processor,so you can't see the NOOK working normally .Your Acer Aspire 9300 battery haven't effect to this mattery ,why you tried taking it out !
1helpful
Acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Acer Aspire 9300 turns on with black screen
Hello!!
Try entering thro the safe mode ... and restore the system. let me know the updates.
Cheers!
2answers
Acer aspire 9300 black screen (display adapter)
I have been fixing computers that has long beeps and short ones. It is usually attributed to memory problem connection. Open the memory compartment at the back of the PC then detach the memory card. Clean with cloth softly enough not to destroy the circuit board or a pencil eraser to clean-up dust that caused the connection blockade. Reconnect after cleaning.
2helpful
2answers
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
My acer aspire 9300 doesn't turn on.
Try this
Remove all power from the computer
Laoptop: remove the battary & the power plug
Desk top: remove the power plug
Hold the power button for 60 seconds
Plug your PC on and reboot
5helpful
3answers
Acer 9300 bios upgrade failed
Hi!
I have the same problem, and my problem was that I have installed 4GB ram and that ram modules wasn't accepted with the new bios. So I installed the old modules and it all worked again, downgraded the bios to one version older and installed my 4GB ram modules and it all worked.
Hope that's your problem too.
Good luck
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
