Question about Adobe Photoshop CS4 Extended Full Version Volume License for PC
Photoshop CS4 Extended will not let me open an image or save if opened through the image (open with Photoshop). After clicking on "open" the program freezes and every click of the mouse responds with a ping.
Posted by david mohr on
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: I need ADOBE PHOTOSHOP CS4 AUTHORIZATION CODE
im sorry this is illegal so i cannot help
Posted on May 28, 2009
yboyandrei
Francis Mark Arango
  • 828 Answers
SOURCE: CS4 Master Suite License Expired
bob_computer didn't give you tips or initiative on how to crack it.
Give me your email address so that i can give you free Adobe Master Suite CS4 (Keygen + Instructions).
If your satisfied my solution, please rate me.
Thank you.
Yboyandrei
Posted on Aug 17, 2009
Testimonial: "Hey, I'd really like to get this fixed. Thanks! [email protected]"
lyzias morato
  • 1566 Answers
SOURCE: could you give me an adobe photoshop cs4 extended
Im sorry, but we do not provide Adobe Photoshop CS4 licenses. I hope you understand that using illegally acquired license keys is illegal. Software piracy is punishable by law so I hope you refrain from using them. Trust me, it is worth to buy a genuine license key.
Posted on Oct 25, 2009
smb_146
Syed Bilal
  • 252 Answers
SOURCE: i cant install the adobe photoshop cs4 becouse i
if u want that for free just download a keygen.
or try the PORTABLE VERSION of CS4 thts free. You can find these on rapidlibrary
Posted on Nov 28, 2009
Anonymous
  • 27 Answers
SOURCE: adobe photoshop cs4 extended serial number
Serial key for: Adobe Photoshop CS4 serial
Windows: 1325-1325-7555-2009-2738-0489
Or
Name: asu S/N: 1330-0414-4416-0263-50¶7-8322 or Name: Cyberspirit 21 s/n: 1325-1454-5884-7210-4830-3247
i hope it will useful for you.
need more key email to [email protected]
Posted on Apr 07, 2010
I want to unstall CS4 extended academic from my pc. But it won`t let me because it say`s I have adobe bridge open in another file/program. The problem is I can`t find where or what program it is. I don`t...
While I have CS5.5 products installed, I believe that CS4 installs exactly the same way.
You need to go to the task manager to stop 'bridge'. To do this click the 'ctrl, alt & delete' all at once.
Then select the 'applications' tab. Click on the 'bridge' icon. then click end task.
Done! You should now be able to do the install.
NOTE: This issue was caused by starting bridge when you start your system up. You might want to go to perferances in the bridge software and turn the 'start when windows starts' off.
Hope this helps you.
Good Luck!
Oct 07, 2011 | Adobe Photoshop CS4 v.11.0 Extended...
Tip
Photoshop
hey friends..... many people have problems with serial no of earlier photo shop versions....
adobe has even released its new version of photo shop cs5 .. very advanced one.... it has 3d object drawing ,lighting, modeling and etc....
so get rid of your old version and use new versions like cs3, cs4 , cs5.... for your convenience i will give you free full version of photo shop cs4 link.... download and have fun friends.... feed back pls..
1. Working: http://rapidshare.com/files/324555240/Adobe.Photoshop.CS4.Extended.PL.part1.rar
2. Working: http://rapidshare.com/files/324554883/Adobe.Photoshop.CS4.Extended.PL.part2.rar
3. Working: http://rapidshare.com/files/324555422/Adobe.Photoshop.CS4.Extended.PL.part3.rar
4. Working: http://rapidshare.com/files/324556591/Adobe.Photoshop.CS4.Extended.PL.part4.rar
5. Working: http://rapidshare.com/files/324554196/Adobe.Photoshop.CS4.Extended.PL.part5.rar
so no serial probs...
on May 15, 2010 | Computers & Internet
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
Serail no of adobe photo shop cs4
Note that "software piracy" is NOT allowed on FIXYA.
So, uninstall it. Download the _FREE_ "Graphical Image Manipulation Program" (GIMP) from http://www.GIMP.org
It does most of what the Adobe software will do, and it is FREE software.
Jun 12, 2010 | Adobe Photoshop CS4 Extended Full Version...
Image posterization in photoshop/lightroom on calibrated monitor
try downsizing the image. Else correct the posterization in Photoshop and set it as wallpaper.
Mar 19, 2010 | Adobe Photoshop CS4 for PC
Key number for photoshop cs4 and activation number
here is the link for  adobe photoshop cs4 keygen
http://www.junkinside.com/wp-content/uploads/2009/02/photoshop_cs4_keygen.zip
Note :
This keygen is made for Free Adobe Photoshop Cs4 keygen And Authorization Code Generator and this keygen is 100% Working and free of sypewere and virus.
Photoshop Cs4 Keygen
If You Want Authorization Code just comment me Serial Number and Activation number
Open Adobe Photoshop keygen befor when you Install Adobe Photoshop Cs4.
Click generate serial button and copy the Serial Number and do not close this keygen.
After installation active adobe photoshop by phone
Abobe photoshop display a activation number
Add activation number in adobe photoshop kengen
Your Authorization Code Display in Adobe photoshop kengen Authorization Code menu
Copy This Code And Past into your Software
Your Work Is Commplete Enjoy Adobe Photoshop Cs4.
Dec 03, 2009 | Adobe Photoshop CS4 Extended Full Version...
All my images in photoship have turned to quicktime and I cannot save back to photoshop. I have gone into tools - open as - but that only opens the images in photoshop it does not help to save them back to...
In order to change what program opens a certain file type in Windows XP, you must change the file association. To change the file association for a specific file, you first need to view the file's properties.
You can view a file's properties by simply right-clicking on the file and selecting "Properties" from the contextual menu that pops up.
Now, in the properties window, you will see a line saying "Opens with:" and next to it the program that opens your file.
To change this file association, click the "Change..." button.
A new window ("Open with") will open where you will choose which program you want to open your file. For example, to open your image file, choose photoshop. If you can't find it on the list, click on "Browse" and search for Photoshop.exe (probably in your Program Files).
If you want Photoshop to open all files with the same extension (e.g. all .jpg files), you should tick the box at the bottom of the "Open with" window saying "Always use the selected program to open this kind of file."
Hope this helps.
Sep 15, 2009 | Adobe Photoshop CS for PC
Reduce Photo
You can use Photoshop to reduce Photo size to a minimum size that can be mailed and u can retain the resolution by it. Its afantastic application. Open your image in photoshop and right clik it on the top of the title bar choose image size and change the resoution to 150DPI or lessere but not less than 72 DPI.
R u can go to save as command in the file menu and save it for Web option is better to reduce the size of the image to very smaller one which can be mailed.
Thanks
Nov 09, 2007 | Adobe Photoshop 7.0 for PC
Open Questions:
See all Adobe Photoshop CS4 Extended Full Version Volume Questions
Adobe Photoshop CS4 Extended Full Version Volume License for PC  Logo
60 people viewed this question
Top Adobe Computers & Internet Experts
Jane
Level 1 Expert
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
