Question about Home
The kohler steam unit keeps shutting down prematurely
Keeps shutting down showing ''error 5'', but i cant find any problem with the water feed.  is it a controller error, or is there a filter inside the unit that gets clogged.  the unit is brand new
Posted by joseph_abed on
  • Anonymous May 21, 2009
    We just installed our new K-1696 and are having the same problem. The water feed is strong and I can't find any filter that may be clogged. I'm calling Kohler in the AM unless there is something I'm failing to check.
Anonymous
    New Friend:
I've been struggling with this exact error for the past week and fixed it last night. The Error 5 message was misleading in my case and actually was caused by the steam outlet inside the shower and, even after replacing the entire unit and getting the same error, i fixed it in two seconds. Since this was one of the posting i encountered during my frantic searches, i thought i would come back and share my blog posting on this error and my fix:
http://fixitben.blogspot.com/2010/01/kohler-k-1658-240v-steam-generator-and.html
Posted on Jan 05, 2010
Donni Steen
  • 687 Answers
Since I don't have your model number for this, I am going to attempt an answer for you. Yes, there could be a filter but not always. Sometimes, the sensor on these units can become stuck closed and is sending a false error. Does the unit seem to be working? If it is, then it probably is a false signal. If not, the there could be debris that has gotten into the water lines. Either way, if the unit is new, then it will be under some sort of warranty. I would contact either Kohler or an authorized service rep.
Posted on Apr 05, 2009
My dehumidifier runs for short time then shuts off.
Check the filters, the water tank and what setting you have it on. The unit will cycle on and off to maintain the humidity level you want. If its set too high, the unit may only have to operate for short periods.
Sep 17, 2015 | Cars & Trucks
Samsung reciever protection error
There is a internal problem. Will have to be taken in for repair,
Dec 01, 2012 | Samsung Av-r730 A/v Surround Receiver...
I have Kohler 12Res generator,sometimes it runs fine and sometime it runs for 5 min and then shut down with error code UU (under voltage).I cant find authorized service center in Pakistan.Please help me to...
If it has a couple hundred hours or more, try cleaning the slips rings on the back of the rotor shaft. They should be very shiny and not black or polished looking.
Aug 09, 2011 | Kohler 12 kW Emergency Power System -...
Kohler Steam Shower. Getting ERROR MESSAGE 5. Need to know how to fix the problem.
check the steam outlet to make sure is properly tight this can cause a false ERR 5
ERR5 comes up when water flow to the unit is blocked or debris has gotten in the unit and clogged check filters,test the water flow
May 30, 2011 | Kohler Home
Error 5
-error 5 is caused by the back pressure of the steam head if water supply to the generator is sufficient and the steam output pipe to the steam head is plumbed according to the manual.
-Kohler recommends to modify the steam head to remove the wax motor, spring and snap ring in the housing. Call Kohler for instructions.
Jan 15, 2011 | Vibrant KOHLER Steam generator control kit...
1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
May 26, 2010 | Kohler Electrical Supplies
I have a Kohler K-7 steam generator/shower and after using it just fine, water now just pours out of the steam outlet - even if the unit is turned off at the control head. I have had to close the inlet...
There is a float valve interior of the steam generator that supplies water to the generator unit. There are no parts available for that unit, and Kohler was useless re: repair. I have the same unit and mine is doing the same thing. I took it apart and there is a washer worth about a nickel that is inside the unit. I flipped the washer over in mine and it worked for about a week....then back to the same problem.
Dec 05, 2009 | Kohler K-1698-G Brushed Chrome Tandem...
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
Steam Shower shuts down immediately now.
probably scale build up from tap water unfiltered. Scale caused by mineral deposits will affect safety systems and auto cut offs in the unit
Sep 13, 2009 | Mr Steam Mr. Steam Commercial Steambath...
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Home Logo
2,206 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
