SOURCE: Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
SOURCE: Dell E173FPf 17 vertical line problem
Yes, but the cost is not worth it. If you get it apart you will no doubt find a couple of bulging capacitors. Dell site has the disassembly instructions.
I have a Dell 2408WFP monitor and it has been displaying vertical lines with thin blue lines on white background. This occurs when either DVI, VGA, or with no connector. Would you please tell the solution? I have tried all the adjustments available with no success. I am leaning to the replacement of the SLM-240D7 Samsung LJ97-01460A Backlight Inverter card. Other monitors work fine. I have tried all the adjustments available and also looked at all the caps and thy all look in good shape.
