Question about Orion 2500D Car Audio Amplifier
How do you wire it in? Orion 300 prq equalizer
Posted by mark adams on
Jay Campbell
    New Friend:
    Problem Solver:
  • 6 Answers
The prq can be used after a head unit before crossover and amps. it is a preamp/equilizer and you must have an orion amp in the signal chain that uses the 5 pin din plug to provide power to the prq via phantom power. if you have a crossover it must be a brand with the same 5 pin din pinout input and output. the din pinout is 1\+15v, 4\r. ch input, 2\ground, 5\l. ch input, 3\-15v. left to right or clockwise on din. the power can be supplied to the prq with an optional 100 pps power supply unit. rca from head unit feed the input and the 5 pin din is the output .
Posted on Feb 12, 2016
  • Santos Jerez
    Santos Jerez Jan 31, 2018
    300 PHD and 300 PSW much better units
  • Santos Jerez
    Only is a 2 channel cross over
Orion TV codes for Yamaha rav300 wa2030
ORION TV CODES FOR RCA REMOTE CONTROLL CODES?
Oct 10, 2013 | Yamaha RAV-300 Remote Control
Will a 800 watts run an orion h212.2 subwoofer
Depending on the type of amp, yes. not all amps are created equal, just because it says 800 watts doesnt make it so. but a true 800 would be plenty.
Dec 31, 2012 | Orion H2 12.2 Car Subwoofer
Why can't I get on Piratebay.org
*This is news that I have been able to find about The Pirate Bay... hope it helps you understand all they are going through to get their system up and running to supply us with free file sharing. I am very thankful as well.
"Gottfrid Svartholm will be kept in detention for at least two more weeks on suspicion of hacking into a Swedish IT company connected to the country's tax authorities. According to Prosecutor Henry Olin the extended detention is needed "to prevent him from having contact with other people." The Pirate Bay co-founder is not allowed to have visitors and is even being denied access to newspapers and television."
_____________________________________________________
TorrentFreak contacted the Pirate Bay team and we were told that the current downtime is cause by a Power Distribution Unit (PDU) failure.
It may take a while before the site returns, When there's an update we'll post something here."
(Look at the site for more information.)
"This is not the first time that PRQ has been raided. In 2006 Swedish police confiscated 180 servers in The Pirate Bay raid, servers that mostly belonged to customers that were not connected to the BitTorrent site.
At this point it is unclear when the sites hosted or routed via PRQ will come back online."
"The Pirate Bay has been offline for nearly a day following a power outage.
TorrentFreak has been informed that problem can't be fixed remotely, and the Pirate Bay team is trying to get someone on-site later today.
With a bit of luck the site should come back online in a few hours.
TPB is not the only torrent site that's having problems at the moment. Yesterday a raid at the Swedish hosting company PRQ took down dozens of file-sharing sites.
PRQ is now back online but not all sites have returned yet.
This post is from the News Bits section of TorrentFreak where we present stories from around the web in a concise summary format. Full TorrentFreak articles can be found here. If you have a tip please let us know. News Bits have their very own RSS feed."
Oct 02, 2012 | thepiratebay.org
Need to know the input wires pyramid 200 watt power booster
Those would be the ones marked "input". Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Oct 27, 2011 | Pyramid 906 300 Watts (peak) 10 Band...
I have a 300 watt amp, but i just bought 12 gauge wire why wont it allow sound to come from my 12'' sub
There is no reason even if the wire was to small it would still allow ssound.make sure you have good connections.
Nov 08, 2009 | Pyramid 906 300 Watts (peak) 10 Band...
My Orion d-5000 amp which is wired to an Orion hcca 12.2 sub cuts out at high volumes , it's wired with 0 guage wires
Your speaker is a dual 2ohm sub. If you have both voice coils wired Parallel that will drop the ohm load to 1, which the amp can not handle. You need to wire the voice coils in series. Treat each voice coil as a speaker.
Jun 30, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Wiring Diagram For Orion 250sx
HERE is the info you're looking for.
Thanks for usnig FixYa - a FixYa rating is appreciated!!
Feb 24, 2009 | Orion Car Audio & Video
Installation
take two out puts from your cd player and run them in the inputs of the equalizer and believe me they are going to work.Remember if the outputs from your CD player are of high note (out put)the volume should be kept at minimal to avoid the rumble.
Aug 18, 2008 | Pyramid 10 BAND EQ 300 W WITH LIGHTS Car...
Color on the screen
Try moving the speakers away from set.
May 11, 2008 | Orion1934 19" TV
Orion 2500D Car Audio Amplifier Logo
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Joe Taylor
Joe Taylor
FastHarley
FastHarley
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
