Hello. Quick answer...bad sub and amp combo due to fact that your sub needs a lot more power than this amp can produce (I'll explain later). But here is how you can do it: You can wire this dual 4 ohm sub in parallel or series. Parallel wiring would be to wire two the positive terminals on the sub to each other and
wire two the negative terminals on the sub to each other. Thus wiring down the sub to 2 ohm. This what the amp would see. Series
wiring would be to wire the positive and negative terminals on the same side of the sub to each other. Then wire the positive and negative terminals on the other side to the amp. Thus wiring the sub to 8 ohm. This what the amp would see. Illustrations can be found here:
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=42#results
Your sub specs are 1500 watts rms (how many watts your sub needs to operate efficiently or its minimum requirement. It has the a peak wattage at 3000 watts that it can accept in short duration. Your amp can only produce 300 to 600 watts at 2 or 4 ohm respectively. So you would be greatly under powering the sub which would produce a weak unfulfilled sound. You need an amp that produces a true 1200 to 1800 watts rms. There is a great selection out there.
