Toshiba 43H70 43" Rear Projection Television Logo
Question about Toshiba 43H70 43" Rear Projection Television
Automatically powers off, flashing red LED
My tv will run fine for a few minutes, then it will power off with a flashing red LED. I have to unplug and plug it back in to get it working again. It will work for 30 seconds or a minute and do the same thing. I suspect something is overheating, as it stays up longer when started cold and shuts down more quickly once warmed up. Any suggestions?
Posted by ThomasLane on
  • ThomasLane Sep 04, 2007
    Additional info: A split second before the screen goes dead, it looks like it loses the red signal. The picture goes green/blue, and then shuts down.
Anonymous
    Sergeant:
    Champion:
  • 375 Answers
Try removing one neck board at a time and see if it stays on and longer,don;t let the board touch any metal or a short wil follow and you got problems.try the red first,
Posted on Sep 12, 2007
Flashing red led light at power; no tv. will not turn on just flashing red led
Try leaving it unplugged for a little while.. at least 15 minutes and then replug and try.
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
I have 40''polaroid lcd(4011TLXB). Powers up like normal with LED changing from red to blue then screen turns black and LED remains blue. I've tried unplugging power cable and waiting a few minutes be
I also had blown capacitors on my power supply. You can see when they're bad: the tops split or bubble up like a dome. I changed most of the caps, just to be sure, and it fixed the problem. Careful of the larger capacitors. They stay powered for some time and can shock you pretty badly. Good Luck
1helpful
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
2helpful
Tv turns off
Hi, your power board is in a weak state. this is being caused by major component failuer. replacing the power board will fix this issue.
VIORE tv/dvd combo
If the red light flashes at plug in you likely have a main board that is bad. If you have to press the power button before the red light flashes you likely have a bad bad supply board. This will need to be diagnosed by a technician to be sure of the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
5helpful
2answers
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
