Question about Ariston Technologies AW129NA 16 Lbs Front Load Washer
Ariston margherita 2000 al 109 i cannot open the door
5 Related Answers
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Posted on Feb 13, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Posted on Apr 18, 2009
Anonymous
  • 10 Answers
SOURCE: we have the Ariston Margherita front loader
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on May 17, 2009
hotpoint jon
  • 353 Answers
SOURCE: Need User Manual for Ariston Margherita 2000 AB 40
Temperature control or speed control for spin
Posted on Dec 15, 2009
Anonymous
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
Need a user manual for Ariston Margherita 2000 Mod. AC 80L s/n 303243031.
go on to the ariston web site with the details from the label as you open the door
Mar 19, 2014 | Washing Machines
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
Something has blown in margherita 2000 and can't open door
hmm sounds like a spring has busted inside your washer there and the diagnostic computer inside the washer was damaged so its not able to unlock its door....
Dec 16, 2017 | Ariston Technologies AL128D Margherita...
I am looking for an user guide/instruction manual for Ariston Margherita 2000 Al109X Does anyone have one?
I'm not sure if this is the exact model but it is for an Ariston Margherita 109. Here is the link to download the manual:
http://laundry.manualsonline.com/regman/exit/ct?url=aHR0cDovL2ZpbGVzLm5ha3Vwa2EuY3ovZWxla3Ryby9lYi0wNjQyMi5wZGY,&target=productDoc&idDeviceType=3004&idMfg=5539&idProduct=269002
Click on the above link or copy and paste the link to your browser address bar.
Note that the manual is in PDF format and will require Adobe reader to open it. If you don't already have Adobe reader you can download it for free from www.adobe.com
Best wishes,
Graemevm
Mar 08, 2010 | Washing Machines
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Technologies AW129NA 16 Lbs Front Load Washer Logo
88 people viewed this question
Top Ariston Technologies Washing Machines Experts
Marvin
Marvin
Harrie
ray gallant
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
