Question about Precor EFX 5.21s Elliptical Cross-Trainer
Precor Error Code 42
Error Code: 42
Manufacturer: Precor
Model: All Models
Error Description:
Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40.
Possible Reason:
Recommended Action:
Lift Position Value Out of Range Precor Error 42
Posted on May 14, 2014
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
SOURCE: How do I replace the
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots on whom the sell parts and support to.
There is a place on line to get some of these, it is. www.treadmilldoctor.com/Products-Services2/precor-treadmill-belt.
The manual can be found at. fitness.manualsonline.com/ex/thread/view/idThread/2141832
This place has manuals and user manulas along with support and some partswww.shopwiki.com/Precor+EFX+5.171 I believe this unit has a 10 yr warranty with it and the part in question may be covered by them. There is also a 1 year part warrant for other parts, I just don't know what parts they are covering for the 10 yr.
Posted on Dec 26, 2010
Dec 28, 2015 | Precor 546 Elliptical
Oct 02, 2014 | Precor EFX 546i Elliptical Version 4
Nov 13, 2013 | Precor EFX 5.21s Elliptical Cross-Trainer
Jul 02, 2013 | Precor EFX 546i Elliptical Version 4
Mar 30, 2013 | Precor EFX 546i Elliptical Version 4
Feb 17, 2013 | Precor EFX 546i Elliptical Version 4
Jan 07, 2012 | Precor EFX 546i Elliptical Version 4
Aug 17, 2010 | Precor EFX 546i Elliptical Version 4
Mar 19, 2010 | Precor EFX 546i Elliptical Version 4
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
286 people viewed this question
