Question about Proton Televison & Video
How to solve proton waja auto gearbox oil leaking problem
Posted by yugendran yugen on
5 Related Answers
onyeredson
Paul W
  • 404 Answers
SOURCE: Oil leak
Hello Pierre,
A little more detail may help me on this one, however this sounds like possibly your power steering pipe? both these use auto trans fluid it is reddy brown in colour and viscosity (Thickness) watery.
If this is the pipe, check the fluid reservoir it should have either a Yellow top with power steering or a steering wheel diagram on it.
If full then please give me more information as to location on engine where pipe comes from and goes too as nowadays engine oil is usually internally dispersed. Only oil cooler pipes possibly? will go to a finned type radiator usually near the front grille of the vehicle.
I hope this points you in the right direction as I'm thinking of giving this help up as very hard to remain on top slot when loads of questions responded to and no replies.
Good Luck,
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Posted on Jan 18, 2009
Anonymous
  • 1118 Answers
SOURCE: gearbox oil leaking
Dip stick tube has a rubber boot it slips thru, that seals it to trans. If its got a kick down cable there is a rubber o ring on that too, or front pump seal on trans is leaking.
Posted on Feb 14, 2009
kirtec auto
  • 1348 Answers
SOURCE: what type of gearbox auto transmission oil?
dexron 3 .
better yet use synthetic from BG which surpasses all transmission fluids and warranty requirements.
Posted on Aug 18, 2009
Ronaldbrains
  • 881 Answers
SOURCE: leaking transmission oil from the back of the
YOU carnt have a transmission oil leak from the front axle on a Falcon as they are Rear wheel drive but could be the hose going to the radiator over the front end leaking But the rear end of G/Box should be only the OIL SEAL.
Posted on Sep 19, 2009
Anonymous
SOURCE: i have a proton waja
Dear sir, if you change the ecu, u need to reset the combra cable, this seting only can done by proton service center, because it combra cable got the coding inside you need to reset it. anything email to me at [email protected] by.. joseph
Posted on Oct 05, 2010
Would like to know where the top up plug for my gear oil is and if there is a dip stick manual proton savvy bt 2006
Manual Transmissions don't have dip sticks.
2. Manual gearboxes have a drain and filler plug. The filler plug is usually found in an accessible position on one side of the gearbox which has to be accessed from under the vehicle.
To top up the gearbox the car has to be perfectly level so if you need to add oil to the gearbox you ideally need to get the car up on a garage hoist/lift so you can both access the filler plug easily, remove it and pump in the fresh gear oil. The usual correct oil level on these gearboxes is level with the bottom section of the filler plug opening in the gearbox. However you should check with the proton service staff on the correct procedure for topping up the manual gearbox in your car.
Mar 20, 2016 | Proton Cars & Trucks
What type of gearbox oil do u use for a 2006 1.2 proton savvy
If it is auto or AMT, use Renaultmatic brand. If manual, any good brand will do. Group SAE80.
Dec 18, 2013 | Proton Savvy Cars & Trucks
Proton waja immobilizer
test the ignition coil see the instruction attached AND fix it.
God bless you2905aaac-86a9-4506-abfb-42f1e01a897a.jpg7b3ec7f3-4775-4f58-83be-65f24e821612.jpg13fa820c-74a4-43bf-b639-0d6a0ce7b153.jpg3b0a633a-9d94-4249-8088-948557d4f8a7.jpg88fe77db-b163-4618-8c6c-7ec518ecae94.jpgbd6aed0c-0d33-4efd-80d8-9c1d2558c526.jpg
Jul 09, 2013 | Cars & Trucks
Wiring diagram of proton waja
saya sedang mencari sesiapa yg nak menukar enjin auto kereta waja ke enjin manual..
Sesiapa berminat sila hubungi saya di 010-9090 767
Mar 24, 2012 | Cars & Trucks
Where are the spark plugs 04 proton waja 1.6
if it is like my 4 banger '99 MB, remove the "panel" from on top of your engine
Dec 10, 2011 | Mitsubishi Cars & Trucks
Oil leaking from bottom of gearbox
if a manual gearbox ,then its fairly easy to repair without stripping box and thats to pump a grease gun full of LM grease into gearbox as the grease will settle in the bottom of the box stopping the oil leak but a auto box will require looking at
Mar 12, 2011 | Volkswagen Golf Cars & Trucks
I have a proton waja 1.8,after replace ecu,can not start up the engine
Sep 05, 2010 | Renault 18I Cars & Trucks
Televison & Video Logo
227 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
ray gallant
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
