Question about Dell Xps 15 L502x Subwoofer Speaker Pn57g
Dell xps 15 L501x sub woofer giving crackling sound
Cybertroy Corps
    New Friend:
Hi you can detached or disconnected the subwoofer cable, for temporary or permanent fix, as the speaker sound also produced good quality sound..
here how i disconected the subwoofer cable, it easy to find at the bootoom, see also utube video inside the link given below
http://atozcs.net/dell-xps-l501x-subwoofer-produce-distorted-crackle-sound/
Posted on Jul 13, 2015
2answers
Change hard drive
Hi, i would advise have have a quick look at https://www.youtube.com/watch?v=g4cS8viw0Ho, this shows you your exact make and model of laptop and how to change the hard drive on it
DVD will not read any type of disk.
If there is an EXCLAMATION Mark for the DVD, the device could just be failing on you.
1helpful
Crackling subs
After crackling sound they stop and the light on overoald
Sound drivers samsung laptop
Sounds like a problem in the setup.
Dell xps l501x wont read disc
if any disc then change dvd writter
Hi, i already bye a new lapt top (Dell XPS 15 L501X /i7-740QM)\r\nand when i start to open the integrated webcam the windows shut down and blue screen showed that error hapen ..... can you help me...
How do you launch the webcam, thru IM, Skype, etc?
Check if you have dell video chat application installed.
Another thing you need to check is if the driver is installed. Seeing as it's new it should've been installed, but go ahead and check.
START>RUN>type DEVMGMT.MSC>ENTER... look for imaging drivers. If you see a yellow question mark driver needs to be loaded.
Get them here: http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
Good Luck.
Thanks for using FixYa.
2helpful
Powered Sub Woofer emitting lound crackling noise
i would say so sounds like woofer is dying unless u pull it apart and replace the woofer it doesnt have to be same brand just same size and watts and ohms then u can keep it
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
Dell Dimension 5100 speaker interference (hiss, pop, crackle etc)
Try downloading the audio driver from Dell at the following link:
http://support.euro.dell.com/support/downloads/driverslist.aspx?c=uk&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIMENSION%205100
Save it to the C: drive in a location you can find. Then run the file to install it.
Dell Xps 15 L502x Subwoofer Speaker Pn57g Logo
Top Dell Audio Players & Recorders Experts
Ekse
Mandeep  Singh
Mandeep Singh
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
