Question about Zanussi 24 in. DE6965 Built-in Dishwasher
My dishwasher is zanussi de 6444 the problem is the dishwasher is the led of the programe or the indicator is not on and the dishwasher is giving strange soynds any help please
2 Related Answers
dave wilde
SOURCE: The Zanussi Aquapulse (de 6965) Fault Code AL3.
Eureka! thank you FixYa. My Zannusi de6965 was failing to heat up andf finish the programe and showing Al3 read a number of your contributers and after stripping down the front of the DISH WASHER found my way into the main circuit board and there they were 2 two DRY JOINTS ( where the blue and orange wires connect) cleaned and re-soldered then re- assembled and tested.... Eureka! it worked just fine.Remember to take care when disconnecting the internal wiring from the circuit board. I colour marked each connector block and made a drawing. Thanks again hope this helps.
Posted on Jan 02, 2012
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: zanussi dishwasher ZSF6161 starts program then stops after 15 minutes
check this steps and fix it. God bless youFloat Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control.
Posted on Apr 02, 2013
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
DE 6850 not drying
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 16, 2010 | Zanussi 24 in. DE6850 Free-standing...
I have a Zanussi DX6453 dishwasher. Water will
Try tipping the dishwasher back to see if any water drains out from below if there is water present then the anti-flood device is energised and stopping water coming into the unit.If it works now after resetting then there is a leak under the machine that needs investigating.You can try going into the diagnostics to read the alarms.If you hold in the first and third button from the left on programmer,whilst holding in then press the on/off button then when the lights start racing release these 2 buttons.You should now be in the diagnostics,now press the first button once and count the flashes of the end of cycle LED.If this button is pressed 2 more times it will give the previous alarms.1 flash could indicate fault on inlet water and valve.2 flashes drain circuit blocked.3 flashes anti-flood device.8 flashes faulty circuit board.Make sure after reading alarms to switch off unit then on then off to reset.Then go back into the diagnostics as before to reset alarms but this time press button 2 from left all LEDS will flash after exit as before.
Hope this helps.
May 15, 2010 | Electrolux Dishwashers
i have this now- another site suggested its the heater, or rater the circuit board. I have just taken it apart and have two dry solder points that are identified quire easily by soot around the area. so now off to find my soldering iron!!
Sep 26, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Dishwasher not getting hot or drying
Same Problem Here - I Noticed your Post is quite old - Please did you solve the problem my friend..........???
[email protected]
Apr 29, 2009 | Zanussi 24 in. DE6844ALU Free-standing...
Is my zanussi aquapulse de 4744 dw hot or cold water fed ?
It is more than likely hot water fed. You can trace the line probably to under your kitchen sink and see where the line follows up to your hot/cold on your sink. There would be then another line coming off the hot which would lead to your dishwasher.
Jan 17, 2009 | Zanussi 18 in. DE4744 Free-standing...
WATER NOT HEATING IN MODEL DE 6850 Zanussi DISHWASHER
YOU NEED TO LOCATE THE THERMOSTAT AND CHECK IF ITS WORKING CORRECTLY IF THE READIND ON THE STAT IS FINE YOUR ELEMENT MIGHT BE FAULTH.BEST YOU GET A TECH TO ASSIST YOU AS ITS A TUFF JOB TO DO ALONE.
GOODLUCK.
MOHAMED
Sep 19, 2008 | Zanussi Dishwashers
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
138 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Renee Knafel-Bullock
ray gallant
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
