In order to reset the camera settings to its default values you need to do the following:
1. Press the MENU button 2. Use the left or right arrow keys to select the Settings menu (its icon looks like a wrench and hammer) 3. Use the up or down arrow keys to scroll to the choice that says "Reset ALL..." 4. Press the "Func./Set" button to confirm your choice. This will reset the camera to its factory default settings
Welcome to Fixya. Most Canon powershot from A series up to the professional G series models have the same menu steps in factory resiting. Just follow the steps below:
1. Press the "Menu" button.
2. Press the right arrow once to highlight the "Setup" menu.
3. Press the down arrow five times to select "Reset All".
4. press the "Set" button.
5. Press the right arrow button once to select "OK"
6. Press "Set"
Since you did reset the camera to the factory defaults I have only one suggestion - it is possible someone touched the lens with oily fingers.
In case if the reset to factory defaults did not work completely look at the following settings: resolution (set it as big as you can), compression, ISO (set it to lower value like 100). Also see if you are using any postprocessing effects.
Did you change the exposure compensation setting or the ISO setting? You could go into the menu and find "reset"...follow the on-screen instructions to return to factory default settings.
-Press the MENU button
-Use the left or right arrow keys to select the Settings menu (its icon looks like a wrench and hammer)
-Use the up or down arrow keys to scroll to the choice that says "Reset ALL..."
-Press the "Func./Set" button to confirm your choice.
This will reset the camera to its factory default settings.
