SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal
hardware error.
Recommended Action
SOURCE: hp color laserjet printer 2650dn error 50.2 who to
This is a fuser error. Probably over heating. Try leaving the unit unplugged for one night and try again. If is not working the fuser is defective or depleted and need to be replaced. If the unit is in good shape contact a service center otherwise its better to get a new unit
SOURCE: 30.01.08 error on HP color laserjet cm3530
You're not real specific about the conditions surrounding this error message, so please have a look at this link to begin with. Then see here, with an enclosed link to contact the HP customer support system, should you wish to do so. Make sure you have the most updated drivers and firmware available for your printer, by checking the available downloads here. Here are some articles that will help you to check which firmware version you're currently running.
If, after ensuring that you are running the latest firmware, and manually power cyclying the machine and computer at least twice, you continue to have issues, this article may pertain and could be of help.
If that doesn't work, please consult this list of error conditions and follow the instructions that apply in your situation.
Otherwise, I suggest you contact HP directly using the link above.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
