Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619
Need schlage deadlatch part replacement - Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619
Adam Kosose
    Habit-Forming:
    New Friend:
  • 35 Answers
Go to this link: http://www.schlage.com/en/home/products/products-hardware-accessories.html
Browse door hardware parts and decorative entry door accessories from Schlage.
Locksmith Hamburg NY 716 646 8383 24 Hour Locksmith In Hamburg NY
Posted on Jul 23, 2016
Keypads on Schlage locks
Answer from Schlage.
Thank you for your e-mail. Unfortunately if he had these locks on his business there is nothing we can do as far as repair. And unfortunately there are no dealers who have the parts available for repair. These are strictly residential keypads. I am sorry about this.
Joshua Bozarth
Consumer Loyalty Representative
Schlage Customer Commitment Center
2119 East Kansas City Road - Olathe, KS 66061
Feb 13, 2014 | Schlage Locks & Locksmithing
Weiser deadlatch replacement
Most post style latches will work on these.
Feb 03, 2013 | Weiser Lock Glc9471 K/ai11p Smt 6lr Vb...
Schlage FE595 keypad replacement part
Your best bet is to contact Schlage directly. You can call during Midwest business hours (Mon.-Sat 7-7) at this number:
Warranty & Technical Information 1-888-805-9837.
For further information for the FE595 (installation & programming manuals and videos), go to this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionsandManuals.aspx
The manuals are PDF files. If you cannot open them for viewing, you need to first download & install Adobe Reader, which you can get here:
http://get.adobe.com/reader/
Feb 21, 2012 | Schlage Electronic Lock FE595 Plymouth or...
Need to find code for Schlage keypad door lock but the sticker behind the plate is unreadable. I do have a key.
I don't believe that you can do without the programming code found on the sticker.Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
I urge you to call and I hope that they can help you. Good luck!
Feb 15, 2012 | Schlage FE595VCAM716ACC Camelot Keypad...
I have a Schlage that was in when I bought the house. It is a double key deadbolt lock. Recently my key just started spinning around on the inside lock. The outside one still is functioning. I took a...
I don't have a direct answer, but here is the contact info you need for customer service:
Olathe, KS 66061
Jul 26, 2011 | Schlage Locks & Locksmithing
Schlage camelot key pad does not engage exterior locking knob when you press the schlage button. I have tried three different locks.
Here is a link to the installation instructions:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
It sounds like you may have the Turn Lock Feature disabled. View and scroll down in the instruction sheet to the Troubleshooting portion, where it says " Pressing (the) Schlage (button) does not rotate deadbolt" The solution is to push the PC button, then the Schlage button, then 7 to enable the turn lock feature.
Olathe, KS 66061
May 02, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Door has worked fine for years with a Schalge camelot electronic lock. Tonight it stopped working and you could not open the door with the inside or the outside handle. Key would not open door either. I...
Olathe, KS 66061
Apr 16, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Apr 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Schlage Cobra lock. The lock will not lock
Please re-post your question with more specific information about the problem.
Olathe, KS 66061
Mar 18, 2011 | Schlage COBRA by Keyless Lock
Need to know how to change batteries, I have ten properties with schlage keyless enties
It depends a bit on the lock and how it was installed.
For the Home locks with a panel on the interior of the door, remove two screws and take off the inside cover. These screws can be at the top and bottom or through the plate of the interior door handle. Then remove the 9V battery and install a new one. Put the cover back on and replace the handle, if needed, and the screws. (Do not use a cordless screwdiver - you could overtighten and strip the threads.)
Other installations have the battery inside the panel with the keypad on the exterior of the door. To access the battery compartment, you need to remove the interior door handle or lock. Then pull the keypad section out of the door. The 9V battery will be behind a coverplate on the back of the unit. This cover needs to be pivoted downwards to open the compartment.
The Schlage commercial offline locks (no computer monitoring) use AA alkaline batteries (4 or 8) in a block. The eight battery version has 4 batteries on each side of the block. These are all on the inside of the door. Remove one screw to get the cover off. Then remove two screws to get the battery holder off (this keeps the batteries from coming loose in the block). Replace all of the batteries and resecure both the battery holder and the cover panel.
For the consumer Schlage Locks manuals, see http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx . For information on the Schlage commercial locks. see http://commercial.schlage.com/electronicsecurity.asp . The manuals are available in the Technical Library for each lock type.
I hope this helps.
Nov 20, 2010 | Schlage Locks & Locksmithing
Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619 Logo
273 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
