Question about Sylvania SSC719C 19 in. TV/VCR/DVD Combo
SOURCE: sylvania 6720FDE combo tv/dvd/video
The codes for a combo set are found in the DVD settings or the VCR settings. Try the rca codes for DVD or Vcr and it should work. Although you may find that not all the functions will work properly ( ie: fast forward, open door, etc ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
SOURCE: sylvania 27 in. tv/vcr/dvd combo remote code
find out who sales sylvania, look at what other tv they sale and try there codes. sears is good for this to.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Posted on May 10, 2008
SOURCE: universal remote code for a sylvania tv/dvd Model
I went to Radio Shack an purchased a 15 dollar Phillips universal remote and it worked after entering one code for sylvania combo tv's. I did the Happy dance and now I can watch my tv again.
ONE FOR ALL® URC6131n Universal Remote Control
JiggyChic
Posted on Apr 23, 2009
SOURCE: Our Sylvania tv/dvd/vcr combo remote is not
If the remote is new and OK, then my opinion is the Ir Receiver on the front panel of your TV set is burned, replace it with new ones will solve the problem.
To locate it, follow the Ir receiver that written on the front panel of your TV, behind it is the Ir Receiver .
Posted on Oct 23, 2009
May 31, 2011 | Sylvania 6313CB 13 in. TV/VCR Combo
Apr 23, 2011 | Sylvania 6513DE 13 in. TV/DVD Combo
Dec 09, 2010 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Jul 29, 2010 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Mar 05, 2010 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Nov 11, 2009 | Sylvania SRTD319 19 in. TV/DVD Combo
Sep 23, 2009 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Sep 20, 2007 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Dec 30, 2006 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
24 people viewed this question
