Hitachi 51F59 51" HDTV Projection Television Logo
Posted on Apr 04, 2009
Which input/ant do is used for cable
I just bought the Hitachi 51F59 from a friend. I hooked up a dvd player and watched the movie. Now I do not know what input or ant, I need to be on to watch my cable. Can anyone help please? Thanks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
117
Points
Anonymous
Level 1:
  • Posted on Apr 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
117
Points
If you haven't figured it out yet - I can call you & walk you through the process ( my phone calls are free ). I was very confused at first but my husband helped me. When we watch DVD/VCR movies we place the TV on Ant B 3 & then when i want to return to cable i put it on VID4. This is all done with the input button on the front of your TV or the ANT button on your remote control.
How to hookup and use
A DVD recorder can hook up to any TV that has at least a set of AV inputs (you will need an RF modulator if your TV does not have AV inputs).
Just hookup your cable or antenna feed to the ant/cable input of the DVD recorder and loop it out to the RF input on the TV.
I have a hitachi rear projection tv was watching it changed channels and lost picture and sound. Nothing led up to it.
Check the input cables. It is possible one was knocked lose by mistake. Try from a different input source such as a DVD player. This can lead to a solution, let me know if it works.
Connect hp laptop to tv to watch Netflix downloaded movies
how do i hook up my hitachi tv to my hp laptop to get netflix?
Hooked dvd player up to my olevia tv and don't know what channel to set tv on to watch video. checked all the channels - can't find movie. do i need to change a setting?
U setup ur DVD player in what format?Set it up with a one cable call HDMI?Or u use a RCA cable YELLOW.RED,WHITE to hook it up.The movie play,u push the button on ur remote said INPUT go down INPUT said 1,2,3 so on.If hook it up right the movie,should play in one of this INPUT said 1,2,3 so on.
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
1helpful
Programming dvd player
It sounds like you may not be on the correct input selection on the tv to watch the dvd player. Ther are probably three or four inputs to choose from on your tv. whichever input you hooked the dvd player into on the tv is the same imput you have select using the tv's remote control in order to watch movies on the dvd player.
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Hitachi P42H401
Maryann,
You should have an RCA cable connector with your DVD player (three wire connector color coded yellow, red, white). If you plug one end of that into your DVD player (out) and into the input #1 in the back of your TV that should be sufficient. Then just select from the input menu on your Tv to watch that input. You do this by the buttons on the lower left of the TV. One is marked "input/exit". Pressing that button should bring-up your input menu then use "menu/select" button to select input 1 and try playing the DVD...
I do have the owner and service manual if you need it just let me know...
Bill
[email protected]
Volume won't work in satelite mode
A few possibilities - try volume + on satellite box itself/reset satellite box
Are you using coax or RGB cables? unplug and replug composite or component audio cables if using those
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
