Question about Regal Ware K6725 Kitchen Pro Bread Maker
Fuse for bread machine
I need to find a replacement fuse for my bread machine. The fuse is 10 amps and looks like a miniature stainless thermos with a solid wire coming out of the top and bottom.
Posted by dicklynton on
  • dicklynton Apr 09, 2009
    Kurt,
    Thanks for responding. Radio Shack was the first place I called, and they knew nothing about the type of fuse I described or even what to call it. They just have the typical glass fuses that, I assume, couldn't handle the heat of from being in a mini oven during the bake cycle. I also called Regal Ware. They discontinued their appliance division in 1999 and had nowhere to refer me.
KMusselmann
  • 247 Answers
Have you tried Radio Shack. They might have it
www.radioshack.com
Kurt
Posted on Apr 09, 2009
How to replace thermoblock sensor?
To replace this part you will have to open the jura machine. I found this information out because I had the dreaded error 8 reading on my jura machine which stopped it from making coffee. To disassemble the jura coffee machine you'll need some special tools that I will talk about as I describe how to get to the sensor, make sure you get those tools or something similar.
The problem that you are having is the boiler is not heating properly (heating the water properly), so the taste of espresso will not be good. You need a high heating temperature to get good tasting espresso. This generally happens because the thermo sensor went bad and the electronic board is not sensing the proper heat because the thermo sensor went out.
1. Remove the drip tray
2. Remove the water tank
3. Remove the coffee cover and bean hopper cover (aroma cover)
4. Remove the cover for the pre-ground coffee shut
5. Now you will need to remove the cup warning plate that is stainless steel, it is fastened with 2 security screws. You'll need a Newelectronx t15 torx security screwdriver to take them out.
6. Now remove the top plate, there will be 5 screws fastening it down. Again use the Newelectronx t15 torx screwdriver to take them out. Pull it up to release.
7. On the rear end of the machine, you'll need to remove some weird oval head screws. The only place I could find the tool for this oval head screw was in the Newelectronx Coffee Tool Kit Set. Get the oval tool, which is different from the Newelectronx t15 torx bit and remove the next few screws. There are 2 screws - oval head, on the lower backside. Take off the rear back panel. On the left you'll find the mechanical parts.
8. On the boiler, which is the big metal part that is formed like an upside down tear drop. The thermo sensor is attached to the boiler with a screw - again use the Newelectronx security screwdriver to remove the security screw.
9. The thermo sensor connects to the electronic board. Detach the wire from the electronic board. Now the thermo sensor is off.
10. Replace the thermo sensor with a new jura thermo sensor that has the same wire colors. If the wire color is wrong the contact thermo sensor might not perform as it should.
11. Now put the machine back together. Good luck
Mar 25, 2015 | Jura Capresso Impressa S9 Coffee...
How do I replace ignitor switch in thermos gas grill, if this is what is what I saw?
If that white is ceramic, I think it is the actual ignitor, not the switch.
Apr 29, 2017 | Thermos Stainless Steel Gas Grill
My padels no longer click into place, & come off when baking bread, how do I fix this? Machine is new, baked around 10 loaves
Call Black & Decker, it should still be under warranty. They will send you a new unit or even a new model if this version is notoriously bad, as was the case with my 2500 model. Their customer service is good if you are under warranty, just call and get it replaced.
Jan 14, 2013 | Black & Decker B2300 Bread Machine
Te magna thermatic switch not kicking in
Drain the coolent, fan switch is usually on the radiator 2 wire switch disconnect wire coupler unscrew and replace.
Thermo usually on the head/ barrels or the thermostat if its exturnal (one wire switch) unscrew and replace.
Jan 27, 2012 | 2006 Honda VTwin Magna
I put fruit in the fruit & nut dispenser & it did not come into the bread. What am I doing wrong?
Hi, sorry your dispenser appears not to be working. Unless and until you can repair it you can always add fruit and nuts the old fashioned way. Take a look at your manual and find the program you are using. Find how long the 2nd knead cycle lasts. For example lets say your 2nd knead last 20 minutes. Plan on opening the lid of your machine 10 minutes into the 2nd knead. All bread machines recommend add-ins well into the 2nd knead. Just have your ingredients premeasured on a paper plate next to the machine and fold the plate and pour them in halfway into the 2nd knead of the program you chose. At least that will help you get the bread you wanted.
Dec 30, 2010 | Breadman TR2200C Ultimate Bread Maker
My thermo fans are not kicking in just chasing common faults for this
Hi and welcome to FixYa,
Initial check would be on the fan motor switch. Temporarily jump the black wire to the fan motor switch to ground, the fan should spin. If yes, then the thermo switch may require further check/replacement. If no, check for presence / absence of IGN +12 on the black/blue wire going to the fan motor. To my recollection, the wire is fed by a 10 amp fuse in the fuse box.
Good luck and thank you for asking FixYa. Happy Holidays.
Dec 26, 2009 | 1997 Honda CBR 900 RR Fireblade
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
Kitchen Appliances - Others Logo
173 people viewed this question
Top Regal Ware Kitchen Appliances - Others Experts
Marvin
Marvin
Ruth summersides
Tom Chichester
Are you a Regal Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
