Question about Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan
How do I remove the canopy on the hunter 21871A-420
1 Related Answer
dchandyman
SOURCE: Trying to remove the Hunter
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/41803.pdf
Page 8 of the model 20761 Hunter ceiling fan shows how to remove the canopy trim ring. Ours had double stick tape holding the brushed nickel to a plastic trim ring. Dropped it, then squeezed the plastic ring.
Posted on Oct 01, 2011
Remove the governor from a hunter ceiling fan light kit
If you're talking about the remote receiver, it's located inside the canopy with wires running down the tube to the light.
Dec 27, 2014 | Hunter Dryers
Trying to remove the Hunter Stratford II 52" ceiling fan. The canopy ring rotates approximately 1/4 turn but does not release.
Sep 19, 2011 | Hunter 20761 52'' The Stratford II Brushed...
Fan will not work, but light will. it is model # 21871a-420. the remote will not work either function. there is power at the box. i purchased a new Hunter universal remote model # 27227 and the wiring is...
You have to get the correct receiver for that fan. There's no such thing as a universal remote,no matter what it says on the box. Call 1-888-830-1326 and you can order your correct part.
Sep 04, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
How does the receiver of the Hunter model 21871 ceiling fan attach to the canopy? There are two things on the receiver that seem as though they should connect to the canopy with slots but no slots in the...
if you look at the mount bracket where the ball of the fan fits in to it should fit right above the ball in the mount bracket and if it can fit loose in the canopy thats ok to just long as ou can get the bell housing back up
Jan 23, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Fan continues to wobble at all speeds.
Check to make sure you don't have a wire pinched between the Triangular ball and the canopy. If you don't have anything pinched between it, make sure your electric box isn't loose. If it isn't, pull down moderately on the fan with it off and move the fan around it's full axis several times, which should seat the ball into the canopy better. Almost every Hunter with the HandsFree canopy I've installed, I've had to do this little "procedure" which the manual says nothing about.
Apr 01, 2010 | Hunter 20763 52'' The Stratford II Ceiling...
The canopy doesn't seeem to fit flush up against
You just need to wrap it and tuck it .. You might need to cut some of the fan wires shorter so there is not so much bulk under the canopy cover. The fans are shipped with enough wire leads to be able to use a down rod, They can be cut shorter when the fan is being installed.
Mar 02, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan Logo
466 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
