At the command prompt type chkdsk X: /f /r where X is memory card.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
could be corrupted data or bad app,going to settings and reset to factory default that should fix corrupted data, if it still persists check for firmware updates in the settings, then check for app updates. if it still exists after that return back to factory for warranty repair
Solution To repairdamage tothe firmware, the solutioncan be foundon googleseachengines.Example;Fixtranscendflashdrive,Fix sandiskflashdrive,FixPQIflashdrive,etc.
If you have files that are over 4GB they are not supported on
the PS3, this may include 1080p HD quality video that you want to play
on your Playstation 3 and cannot because the current FAT file structure
does not support files more than 4GB.
The answer
would be a PS3 firmware update to support the NTFS file system, then you
could play 4GB plus video files on your PS3.
I was able to successfully update my Sharp's firmware by using a USB drive that was:1) formatted in (fat, not fat32)2) had only the one update file (.uvp) and3) a small USB drive (4gb - other posts said 2gb or less)
