Question about Bunn CWTF20-3 Automatic Coffee Brewer - 20amp
Weak coffee - Bunn CWTF20-3 Automatic Coffee Brewer - 20amp
jasbo
  • Bunn Master
  • 2,239 Answers
You'll have to recallibrate. use a 64 ounce measuring cup and follow the instructions on the inside of the front panel.
Posted on Jan 15, 2015
My tassimo coffee maker is ruining the coffee it taste like water
i too had this problem BUT it was AFTER i descaled it and did the cleaning, now coffee tastes weak, and ive tried different discs (other coffees) and all come up weak.
Nov 13, 2011 | Bosch Tassimo TAS 4012 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
Coffee has started becoming weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Apr 21, 2009 | Bialetti Mukka Express
Weak coffee is the result of brew
Apr 17, 2009 | Regal Ware 58001R
WEAK COFFEE & NOT HOT ENOUGH
Dec 22, 2008 | Bunn NHB Coffee Maker
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Weak coffee
Jun 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Espresso C15---weak coffee
Apr 28, 2008 | Jura Capresso C1500 Espresso & Coffee...
Bunn CWTF20-3 Automatic Coffee Brewer - 20amp Logo
55 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
