Samsung yp 5k
What did you do when you Samsung yp 5k is doesn't work
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Samsung YP-K3 MP3 Player
Available from Samsung suppoort site along with firmware upgrade tool
Posted on Jul 11, 2008
Anonymous
SOURCE: samsung mp3 yp-u3j no driver
download windows media player 11
once you install it follow these steps:
-right click my computer-click properties-click on hardware tab- then click on device manager
- plug in your yp-u3jqby mp3 player
-you should see your mp3 player pop up. double click it. then upgrade drivers.
after endless hours... i finally got it to work. i guess the trick is windows media player 11.
Posted on Sep 12, 2008
Anonymous
SOURCE: Samsung YP-T9 Driver
Problem video
Posted on Dec 21, 2008
Anonymous
SOURCE: samsung yp s3 doesnt work on xp
I have Windows XP and Media Player 10.
I had same problem with Samsung media studio not recognizing MP3 player. Here is how I fixed it. With the MP3 plugged in, I had to go into System/ Hardware/Device Manager and find the S3 driver under "Windows portable Media" and uninstall it. Then unplug and replug the S3 into the usb so that driver gets reinstalled.
Then I decided windows media player and samsung media studio are unnecessary for transferring music files to MP3 player.
Instead I go into Portable Media Devices from the control panel and just treat the MP3 player like a usb device. I copy folders of music and songs into the Music folder on the MP3. For me this is way easier than the Samsung music studio or Windows Media player.
Posted on Mar 17, 2009
Anonymous
SOURCE: Samsung YP-U3 driver
REALLY REALLY REALLY REALLY WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! yes yes yes yes!!!!!!!!
I solved the problem after i was really crazy of anger with samsung company, but i found this solution in one forum.Thank you
very much, anonymous Guest!!!!!
Hi All,
I just solved the problem after many attempts!
It works for me, and i hope it works for you too~First install media player 10!
When I plug in my YP-U3 player, the computer says it needs to search for a driver, then i let it search it online. But it normally
won't search the driver on the internet. Then, it will give a prompt to ask if you want to find a solution or search the driver from
the PC. Choose the second option, searching from the PC. Then change the directory to C: (Which is the most crucial part).
After a while, the driver should be found and a warning message will appear. Forget about the warning, choose install the
hardware anyway, player should be recognized by then.
(I have had windows media player 11(10 also works), direct X 9...etc. before installing the driver)
Posted on Apr 22, 2009
I cant transfer files to my yp-p2
Go into settings. Samsung, as I now know, stinks. Keep looking it up if this doesn't work.
Jun 16, 2012 | Samsung YP-P2 Digital Media Player
Manual samsung YP-U2
I've found several YP-U2J (not just YP-U2) MP3 players listed by Samsung support. The direct link to the support for the YP-U2JQB/XAA is http://www.samsung.com/us/support/owners/product/YP-U2JQB/XAA . The manual is here: http://downloadcenter.samsung.com/content/UM/200604/20060401094436140_YPU2J-USA-ENGLISH0.0.pdf . If this link doesn't work, start at the above link and the Manuals & Downloads tab. (You'll see a pop-up, click Send.)
Alternatively, start at http://www.samsung.com/us/support/downloads . Select Media Players under Mobile. Then select MP3 Players and finally the model. Then look for the Manuals & Downloads tab.
I hope this helps.
Mar 15, 2012 | Samsung YP-U2 MP3 Player
I need a user manual for Samsung MP3 player YP U6
You can download and print the user manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa
Jun 27, 2011 | Samsung Audio Players & Recorders
Samsung YP U5AB- all files in device accidentally erased. Now the computer software doesn't recognise the device.
my samsung YP-U5AB/MEA is not working when i'm turning it on , the screen doesn't turn on but when i put it on the computer i can save things on it but it doesn't work ....help please ???
Feb 20, 2011 | Computers & Internet
My Samsung YP-T9 MP3 Player wont turn on!!
I think holding down menu and the record button at the same time should fix it. I read the best solution and it just turned on. I was having the same problem, mine would not turn on either but just try pressing and holding down the record and menu button for about 5 seconds.
Oct 18, 2009 | Samsung Yepp YP-T9 Digital Media Player
YP - Z5 MP3 player
have you tried waiting a few minutes after this appears? because if you turn it on for the first time, or you have turned it on after resetting it, it takes a few minuted to load. so if you wait a few minutes the main screen should come up.
Oct 15, 2007 | Samsung YP-Z5 MP3 Player
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
