Need a schematic for nordyne intertherm model e1eb-015ha
Posted by txjayhawker1 on
Donni Steen
  • 687 Answers
Nordyne no longer has the E1 model in there literature not even in their archieved documents but I have included a link to for the E2 model which will be very similar to yours. These units are very simple and all only vary slightly. It should give you enough info to get you through what you want to know.
http://www.nordyne.com/literature/7103180.pdf
Posted on Apr 08, 2009
Cynthia Hollingsworth
    New Friend:
  • 9 Answers
Wiring diagram for E1EB-015H, if you want a better copy I'll need an email address.
need a schematic for nordyne intertherm model - need-schematic-nordyne-intertherm-model-pgo4udvlobv2sheptnserdfd-5-0.gif
Posted on Mar 23, 2015
1992 NORDYNE/INTERTHERM FEHA-015HA-01 DOES THIS UNIT HAVE FUSES
It should have a 3 or 5 amp fuse on the circuit board.
May 13, 2014 | Intertherm Heating & Cooling
Wiring diagram for electric furnance model E1EB-015HA
THIS IS THE WIRE DIAGRAM FOR THE NORDYNE E1EB-015HA UNIT.
Feb 14, 2012 | Heating & Cooling
I need the wiring schematics for a nordyne E1EB-015HA
E1EB-015H Wiring diagram from owner's manual.
If you want a better copy, I'll need an email address.
Aug 10, 2011 | Heating & Cooling
No voltage to thermostat inside blower does not come on and ouside unit does not come on. Nordyne/intertherm model E1EB-017HA
Check the breaker or fuse's then check power supply to the transformer you shuld get 24 volts out of it..
Aug 05, 2011 | Heating & Cooling
I need a wiring diagram for a intertherm model # e2eb-015,017
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Apr 11, 2009 | Heating & Cooling
Wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Dec 21, 2008 | Heating & Cooling
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Open Questions:
My GE window AC Model#AEL06LXQ1 Serial#AM311149P I forgot to add my question. The AC is only a year old/young. It is properly installed in a basement window with ample space outside in the window well which is fully open to the air above the window well is only covered with a window mesh type screen which keeps clean & filters out debris only. Last year around this time it was cooling the entire room nicely however displaying e8 error code intermittently which was a problem. GE refused to advise via phone and set an appt. for a tech. to come over. I did some research and reset, unplugged, waited etc. I have a dedicated electrical outlet for the AC as well. I really do not recall what I did but the unit stopped error coding e8 altogether and worked wonderfully for the rest of the hot season. I cancelled the GE tech. Now this year I am having same problem. Unplugging, waiting, changing settings, resetting to default settings, I have tried everything and to no avail. The AC will run for a while with the compressor in check and cool down the apartment but it doesn't last long, approx. 45 minutes, at best with one or 2 times exception where it held cool overnight. I don't know what to do at this point. I am not too tech-savvy. I also am unable to lift this ac out of the window. I've a back injury and though a relatively small unit, it's too heavy. Please advise. I hope you have an easy fix solution. The user manual doesn't even list the error codes! I have spent hours searching youtube videos and haven't found a solution. Hoping it's as simple as manipulation a setting. Thank you.
Jul 03, 2020 | GE Heating & Cooling
Heating & Cooling Logo
1,481 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
