Question about Measuring Tools & Sensors
Where can I down load an Cen -tech item 92375 5-1
Where can I down load an Cen -tech item 92375 5-1 stud finder manual
Posted by jimmy hailey on
Sandie Gordon
    New Friend:
Wow. That was no help...we post to find links without having to leave the home or the project at hand....
Posted on Jun 02, 2015
I need battery charger cen-tech 69368 manual
Sorry to say, but Harbor Freight's parts list has no internal parts listed. So to fix it yourself, you may be able to find the little tiny diodes that usually go bad. They don't even have a wiring diagram in the owners manual.
Apr 03, 2014 | CEN-TECH Heavy Duty 6/12 Volt Battery...
Tip
DYI Stud Finder
If you don't have the cash to shell out for a new stud finder, or just don't feel like heading to the store for a single item, try this little trick instead. Get a strong magnet, the stronger the better, and gently run it over the wall you want to find the studs in. Your magnet will be attracted to the metal screws, showing you right where your studs are. If you have a weak magnet, then tie it on a string and hold it by that. You'll see the reaction rather then feel it. If your using an old neodymium magnet from a scavenged hard drive, you'll feel the very obvious tug whenever it reaches something metal.
A little searching showed I'm not the first person to think of this, but it's not a trick that's been broadcast very much. Most of the time a search for "finding a stud without a stud finder" will get you results that tell you to tap the wall and listen for the echo. That trick doesn't work with all walls, or even all studs. So next time, grab a magnet.
on Oct 12, 2010 | Measuring Tools & Sensors
Need manual or operating info for a cen-tech stud finder mdl 92375
Re: above answer. There is no button on this model. Now what?
Dec 22, 2012 | Measuring Tools & Sensors
How replace battery in stud finder
It is very easy. Open battery compartment at the back and remove old battery and put new one in.
If you get stuck you can download manual from here:
http://www.irwin.com/support-services/product-manuals
Jul 01, 2012 | Strait-Line Intersect Laser Level With...
How to use a cen-tech stud sensor
Start where your pretty sure wall is hollow. Hold button and slowly slide side to side. When all lights light make pencil mark then start about eight inches away in same direction slide back toward pencil line and when all lights light make another pecil line the center of the two is the center of the stud.
Mar 09, 2012 | Hand Tools
I have plaster walls in an old house the stud finder just keeps beeping how does this thing work?
Your stud finder keeps beeping because old plaster walls have lath boards behind the plaster that are attached to the studs and running horizontally. Try adjusting the sensitivity of the stud finder by placing it on the wall and turning the sensitivity down until it just stops beeping. Then move it back and forth in a wide enough arc to be sure that you have crossed a stud, turning up the sensitivity ever so slightly until you get a tone when you cross a stud. Hope this works out for you.
May 08, 2011 | Stanley Garden
I can't find my user guide, What settings do I use for stud finder?
Hello. The instructions can vary from model to model. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
If this answer has helped, please rate it a four-thumbs up. Thank You.
Mar 27, 2011 | Strait-Line Intersect Laser Level With...
How do i find a stud with the stud finder
Aug 18, 2010 | Strait-Line Intersect Laser Level With...
How do you know when the strait line laser level and stud finder is on a stud
Hello. The instructions can vary from model to model, but most have a green indicator light that lights up when the unit detects a stud. There is a section in the manual (for most models) that will show/inform of the unit's individual method. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
Jun 18, 2010 | Strait-Line Intersect Laser Level With...
Lost instructions to Ryobi EMTP006 stud finder, I don't remember how to use.
1st press and hold the yellow button on the side until " on " is displayed. THEN after 3 seconds unit calbrated and ready to scan. bar graph and audio indicates edge.
sonic tape
just press read and it will read up to 50ft
"x" button gives area and volume
" " for addiction of length
Jul 13, 2009 | Ryobi WallTech Stud Finder Stud Finders
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Bill Boyd
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
