Question about Sanyo Televison & Video
I have an old Sanyo TV and we lost the remote and its stuck on video. Also the channel buttons dont work and when I go to the menu bar the scan channel functions are highlighted and wont let me press on those it just skips to a function not highlighted like volume. Can I get some tips?
Posted by glenda tejada on
Markleague
Sanyo 2010 DP50749 I can’t seem to get my menu button to work I’ve tried everything almost please help
Posted on Apr 02, 2020
3 Related Answers
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: 26 ilo tv comes on but stuck in composite no functions on side works except for power switch
I would contact them on this
http://www.funai-corp.com/support/contact.aspx
in the manual see page 34 for testing the remote
http://www.funai-corp.com/6pdf/om/CIWL3206.pdf
Posted on Jan 31, 2008
pddp
SOURCE: Channel stuck on TV
This may work;
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
Anonymous
SOURCE: Mintek LCD TV DTV-320-D buttons does not work
Be advised that Mintek Digital Inc., the company that has sold portable DVD players, DVD Flat Screen TVs has filed bankruptcy in Federal Court. What this means to consumers is that your product(s) warranties that are within your purchase date are no longer valid. Anyone purchasing any Mintek products with claims of warranties are being mislead. For further information, contact the California Attorney General's Office, the Better Business Bureau or telephone 301-986-666 or email at [email protected] to seek compensation. Remember, if you buy any Mintek product, you are buying a product that cannot be supported or warranted. You are on your own since September 9, 2007.
Posted on Jul 23, 2009
How can I do a channel scan on sanyo tv model DP26648 without a remote?
If you're trying to change the channel, it's the last 2 buttons on the side of the tv.
If you're trying to scan for additional channels you'll need a universal remote.
based on what the manual says you need to press the "menu" key to do a manual channel search.
unfortunately there is no menu key on the side of the tv.
here is a cheap universal remote that includes the menu button.
https://www.amazon.com/RCA-RCR503BZ-3-Device-Palm-Sized-Universal/dp/B007TAMHRI/
2answers
I have an old sanyo t v and its stuck on video and we have no remote for it. I need to change the channel.
usually you can press a combination of buttons on the tv itself to change the input. However each one is different. So I can't tell you the exact combination. Try pressing both volume buttons or both channel buttons at the same time if there is no input button. then use the buttons as singles to navigate the menu when you access it.
good luckk
https://www.6ya.com/mrmmike
1helpful
Sanyo model # ds19310 16 jnch tv stuck on video chanel wont change to any other chanel volume works pat of menue works but the channel search and two other chanel menue controls are not available tv skips...
If you still have the Sanyo remote, you just need to press the INPUT button on the remote. The channel search and some other functions are disabled when the TV is in video/AV/game mode.
If you don't have the Sanyo remote, but you have a Universal remote which you use with the TV, look for a button labelled INPUT or SOURCE on this remote and try pressing it.
If you don't have any remote for this TV or you are using a universal remote which does not have an INPUT or SOURCE button, please reply to me from within this page for further assistance and let me know the brand and model number of any universal remote you are using. There is no option in the menu for doing this, but there a couple of methods which work on some TVs
Hope this helps.
Regards,
BElectric
Sanyo tv channel stuck
A POSSIBLE solution. I have the same stet...got it used, but it's in good condition.
It was stuck on a channel. I went iinto the menu and fiddled with the channel programs and "deleted" the channel and now I can freely change channels.
By the way, I could use a manual for this ...got one?
Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
39helpful
13answers
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Sanyo TV
I too just bought an RCA remote for the same television. The button to access other video screens is the A/B button on mine (next to the last channel button).
Tv is stuck in video mode
The best thing to do is get an original replacement remote and then you will absolutely be able to enter the menu and perform the autoprogram.
2helpful
TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
