WON'T RESTART
The reset button used on Bostitch is the type that cuts out when motor is too hot to safely run. You must wait till system cools a bit before the reset button will reset. May be a good idea to solve overheating problem before replacing reset. It is always best to connect the compressor directly to the outlet instead of using an extension cord. If it is already connected directly to plug, insure that the outlet is capable of delivering amps needed for your compressor. When the compressor reaches rated pressure and shuts off there should be a small release of air from the pressure switch. This release of pressure allows the compessor to start in an unloaded state. If the compressor does not release the air in the hose the motor will not have the power to overcome the backpressure and cause the reset to open. There is a capacitor that could be at fault. The capacitor must be removed from the circuit to test. It should test within 95 percent of rated value. Generally, overheating is caused by low power. A failed capacitor is caused by low power. Good luck, enjoy.
