Question about Amerock 3 Ring Knobs - BP1586
SPINDLE BROKEN DOOR WONT OPEN. ATTEMPT TO REMOVE SPINDLE BROKE SPINDLE BUT DOOR STILL WILL NOT OPEN.
Posted by JAIME CORREA on
1 Related Answer
Anonymous
  • 3 Answers
SOURCE: The knob is broken
youve probably solved the problem by now but i would use a spanner or molegrips on the spindle to turn it, fitting a new one would have fitting instructions included.
Posted on Oct 20, 2008
Sharp Carousel Microwave door won't open, button broke
Take it to a Discount Appliance or Used Appliance store and have them repair it. There they will have the parts that are used and cheaper to repair than hiring an Appliance Service Technician.
Option 2
Take the microwave apart and go to www.searpartsdirect.com and type in your model number and find the broken part and part number. Then order the part through ApplianceZone.com or ApliancePartsPro.com. Later when parts arrive at your door... install theparts yourself and save money!
Mar 27, 2014 | Sharp R-1480 Microwave Oven
BROKE DOOR HANDLE
You will have to open the door, and remove the inner door panel to remove the outside door handle. I would suggest getting another door handle from a wrecking yard if the new one is expensive. I hope I could help. Thanks
Mar 13, 2014 | 89-94 Ford Explorer / Ranger LED Black...
My driver side door handle is broke on the outside and inside, I cannot get the door open to remove the panel.
You may be able to remove the front fender and drive the pins out of the door hinge.
Jan 01, 2014 | 2001 Chevrolet Tracker
Rear door wont open on 2000 gmc savanna
sounds like your lock rod clip broke, have to remove door panel inside and release it to open then repair lockrod
Nov 27, 2012 | 1997 GMC Safari
Door latch broken on 1999 acura tl
Make a trip to Harbor Freight. They sell plastic, car body trim pry tools. Cheap! These will give the the leverage you require to remove the door. As you have limited range of motion from inside the car, you may attempt to grab the door panel at the bottom, and pry the top in ad up and down motion, to free the plastic door retainer clips. Be careful. Old, sun stressed plastic can split. Better to make a quick trip to the salvage yard, with your new pry tools in hand, to gain experience removing the trim. Once done, you'll know exactly the locations of your trim retainers. (This will tell you exactly the sweet spots in which to apply your leverage) Good Luck.
Oct 03, 2017 | 1999 Acura TL
Detergent holder wont spring open
I suspect the spring is actually broken.
You may be able to order a spring - but unfortunately may only be available as a complete unit.
Try a replacement from Ebay if possible - otherwise order via appliance spares.
Fairly easy to replace - but disconnect from power before attempting to remove door.
Aug 04, 2009 | Dishwashers
The door wont open how do i open the door lock is broke other 3 doors open, drivers door will not open is there a way to open door to fix it
Apparently you'll have to take it apart yourself and identify the part you need - OR - take it into the Hyundai dealership and have it diagnosed and they will give you an estimate of repairs.
May 16, 2009 | 2000 Hyundai Sonata
BROKEN REAR DOOR HANDEL AN WINDOW WONT GO DOWN!
using small hook tools and tack pullers shaped like mini wonder bars, you can remove the door panel. once removed, you can fish around on the bottom middle of the door and pull the cable to unlatch the door.
Apr 14, 2009 | 2001 Toyota Sequoia
The knob is broken
Sep 28, 2008 | Amerock 3 Ring Knobs - BP1586
Amerock 3 Ring Knobs - BP1586 Logo
79 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
