Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Has a problem does not work at NOT Wash the Dishes WHAT TO DO;;
Posted by kiriakos on
Mike
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Are the dishes spotty or cloudy? if so it is your hard water and not the dishwasher. go to www.dishwasherfilter.com and get their system. works awesome and guaranteed to solve your problem if the dishes are cloudy or have a white residue on them.
Posted on Aug 08, 2013
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Why dishes are not cleaned on top of dishwasher but the bottom dishes are cleaned
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Feb 23, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher leaves baked on soap scum on al dishes and everything ....even on the dishwasher ...tried all kinds of soap and rinse aid...nothing works...cleaned entire washer out cleaned all filters...
I imagine you've already checked that you're using the correct amount of detergent for the wash programme, and that you're washing the correct quantity of dishes for the wash programme, though if not, try that first!
Is the dishwasher heating the water to the correct temperature? If it's not rinsing at a hot enough temperature, the detergent may leave a residue. In that case, your dishes would probably also be less than entirely clean; they could be slightly greasy when removed from the machine.
Another possibility is that insufficient water is supplied to the dishwasher, so it might be worth checking the tap that lets water through the hose and into the machine. Does the tap turn on fully? Does it turn off properly?
The other thing that might be worth trying is an empty wash: put the machine through a wash programme WITH detergent but WITHOUT dishes, at the programme with the highest temperature. Is all the soap scum washed away? Or is there still a residue inside the machine? If the empty wash works, you probably need to give your machine a maintenance wash once a month or so. This is often the case if you usually wash your dishes a few at a time on a short programme.
I hope some of that helps. Good luck!
Oct 09, 2010 | Bosch Dishwashers
Doesn't seem to wash the dishes. Maybe the wash
make sure the sprayarms are free from food deposits
and also spraying off food from dishes may help out check hot-water is on and heating element is working
Nov 25, 2009 | Dishwashers
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Ultra wash dishwasher is very loud. Dishes come
i put house insulation around mine it worked very well just take off bottom panel and put it in if you can get to the top put some there too...thumbs up
Aug 12, 2009 | Dishwashers
Fills with water and drains will not run to wash dishes
The main water pump is not working. A repair will be pricey. it may be best to get a new dishwasher
Apr 21, 2009 | Dishwashers
Dishes not clean, water spots
You might have really really hard water which would leave mineral deposits on your dishes,,, something could also be blocking the wash arm from rotating, or the water from shooting out of the wash arm which would result in very poor cleaning results
Mar 12, 2009 | Dishwashers
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Oct 11, 2007 | Kenmore 15529 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
95 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Renee Knafel-Bullock
ray gallant
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
