I have power to the roof but I think the ribbon cable that connects the t-stat to the board is separating. Do I have to replace the entire board?
Electrical wiring is something dangerous to work with so I suggest you should leave it to professionals.
Posted on Sep 10, 2020
In my own oppinion I would if it is available, as you do not know if something shorted out..also note that you may have too as updates are constantly done in the RV bussiness..I worked at 2 RV dealerships and there were constant updates especialy Dometic refrigerator and cooling units. Stop at the local Rv shop and see what they have or they may order it for you.
Posted on Apr 04, 2009
Dec 28, 2015 | Sanyo DP50747 50 in. Plasma TV
Dec 29, 2014 | Maytag Appliances Over-the-Range Microwave...
Dec 24, 2014 | Dometic Heating & Cooling
1.
UNPLUG
THE MICROWAVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2. 1. Remove the top front cover by removing the (2)
screws that are along the top edge (phillips).
3. 2. Slide the cover to the left about a half inch
(there are tabs holding the cover in place) and remove.
4. 3. Remove (1) screw from the top of the Keypad
Housing (phillips). Lift the Keypad Housing upwards about half an inch (there
are tabs holding the Keypad Housing in place) and remove. Be careful of the
metal grille that is just above the Keypad Housing as this may fall out since
it is being held in place by the Housing.
5. 4. Be careful not to pull on the wiring harnesses
that are attached to the Housing. Carefully unplug the wiring harness
that has the RED connector on it from the circuit board. Carefully unplug the
small white connector that has the mylar ribbon cable on it (this cable is
see-through and you can see thin, flat wires in it).
6. 5. Remove (4) screws that are holding the circuit
board onto the Housing.
7.
The Housing should now be free of the circuit board
and wiring harnesses. It's safe to let the wiring harness/circuit board hang
free, but caution should be used anyway.
8. 6. Remove the thin metal frame from the Housing.
There are (4) plastic tabs holding the frame in place. Using a small screw
driver pry one side of the frame away from the housing (try to do this to the
side that has smaller plastic tabs). When this side of the frame is free of the
Housing you have to lift the frame out at an angle to remove. It might put up a
fuss, but be patient and be gentle with it since the frame is thin and fragile.
9. 7. With the frame out of the way you will see the
mylar ribbon cable that is coming out from underneath the Keypad assembly. You
will notice that the mylar ribbon cable folds back onto itself as it re-enters
the Keypad assembly. This 'touching of the two ribbon cables' is where the
trouble lies. The ribbon cables may be stuck together. Carefully separate these
two and then insert a small piece of paper between them (paper can be 1/2 x 1/2
) and work the paper all the way down into the Keypad assembly as far as it
will go.
10. 8. Using electrical tape, apply a small piece
between the ribbon cables to hold the paper in place. Next, use more electrical
tape and put it between the mylar ribbon cables enough so as to keep the ribbon
cables separated.
11. 9. Re-attached the thin metal frame making sure to
press it into the Keypad assembly enough so that the (4) tabs click into place.
12. 10. Use electrical tape and apply it to the raw
metal edge of the thin metal frame to prevent the mylar ribbon cables from
rubbing on the metal edge.
13. 11. That's it. A final word of caution. Be careful
when inserting the ribbon cable connector back on to the circuit board. The
connector is loose and you need to gently place the ribbon cable into the
circuit board connector.
14. 12. Reverse the order of assembly from above.
15. 13. Plug in the microwave and then it should reset
and ask you to set the time.
16. Hope this works for you !!
Jun 13, 2012 | Samsung SMH9187ST Microwave Oven
May 12, 2011 | Acer Aspire 6930-6455 Notebook PC
Sep 16, 2009 | Heating & Cooling
Aug 23, 2009 | Televison & Video
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Feb 08, 2009 | Dell 926 All-In-One InkJet Printer
124 people viewed this question
