My Dell Inspiron D531s shuts off as though the main power failed every few hours, usually runs all day or if I leave it alone for a couple of hours it shuts off
No Hibernate,No sleep, Full power, I have a problem with Sleep (hibernate) when I do I have no sound after I wake it up. I have to restart 1 to 2 times before sound re-appears. But this is another issue, over night it will just dieNo Hibernate,No sleep, Full power, I have a problem with Sleep (hibernate) when I do I have no sound after I wake it up. I have to restart 1 to 2 times before sound re-appears. But this is another issue, over night it will just die
I would ensure your CPU fan is working properly, there are no power input issues: cord is all the way into computer and outlet as this would cause overheating of the cord or supply, try another wall socket on another wall, if you have a power strip, it may be faulty and/or a self resetting one.I would ensure your CPU fan is working properly, there are no power input issues: cord is all the way into computer and outlet as this would cause overheating of the cord or supply, try another wall socket on another wall, if you have a power strip, it may be faulty and/or a self resetting one.
Well only for 2 or 3 days--- see if the problem continues--- if it does not continue if it does--- post back and we sahll continue troubleshooting.Well only for 2 or 3 days--- see if the problem continues--- if it does not continue<we have a winner> if it does--- post back and we sahll continue troubleshooting.
DELL BEEP CODES Beep CodesBeep CodeDescriptionFailure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
You've checked the p/s and it has volts out. Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone. Laptops should be run on battery alone as much as possible, or the battery dies.
Thats just your computer ending the process of skype.
As for the pc shutting down automaticly it can be that its oveheating!!
On my Dell Inspiron 2200 I get the Blue Screen every 2 hours and I dont mind.
Might be bad memory
If the computer will run on battery alone, and you cannot fully charge the battery, it's probably time for a new battery. The life expectancy is 2-3 years if treated right. Some people get a lot more life than others. Here's a suggestion: when you run your computer, let the battery run fully down at least once a month. Do not leave it plugged in to line power all the time. Do not keep charging it when it is only a little bit discharged.
Thanks, It is plugged into a backup battery power supply, do you suppose that may be faulty, should I remove it?
Thanks for your help I'll give it a try and let you know
Dave
