Air and heat blower will not come on. 1998 sonoma 2.2l
start by checking fuse. if fuse is good, aquire a test light, check the test light on the battery to make sure the test light works. Power to ground = light. access blower motor under pass-side dash panel.(probablly have to remove underdash cover, secured with pop-in style fasteners.) locate blower motor. 2 wires w/connector Purple-power, black-ground. check for power at purple w/test light on known good ground, with ign on, and blower switch on high. if it has power, hook clip of test light to a power source, ( + on battery w a jumper wire) and probe black wire, with test light. if no light, jumper that wire to a good ground. if it lights, you have a bad b-motor. if no light on power side of blower motor, and fuse is good, check power to swith. blower circuit may have 2 fuses. 1 for high and a 2nd for the lower speeds. if switch has power to it, and power is transfered to another wire when switched, suspect the blower motor resistor. James White, White Automotive, Hopkins Mo. ASE tech, 17 yrs exp.
