Question about Carrier 38CKC030 Air Conditioner
Air conditioner fan not working - Carrier 38CKC030 Air Conditioner
Radiator cooling fan, air con & central locking not working
Search Results
    newrremedies - Range Rovers
    www.rangerovers.net/newrremedies.html
    Feb 1, 2012 - Shop Manual: To diagnose and cure problems on the 4.0/4.6 it is almost... When the air conditioning failed during a summer off-pavement expedition in the..... the security/central locking portion of the service manual describes a process .... I asked the dealer to check the radiator and the viscous fan clutch.
    Air Conditioner Fan Not Working - Repair Parts ...
    www.repairclinic.com/RepairHelp/...Air-Conditioner/...---/Air-conditione...
    Heating & Cooling ..... Most Frequent Causes for Air conditioner fan not working ... On one side, the fan blade draws in outside air over the condensing coil to ..
Jan 13, 2016 | Cars & Trucks
Why wont the fan work?
Good Afternoon Friend,
I understand that the fan is not working in your Frigidaire air conditioner, model# FRA106BU1. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your air conditioner and determine why the fan is not working. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire FRA106BU1 Air Conditioner
How to replace coolant in air conditioner...
fan motor is bad stuck or relay or capictor if fan dont pull air thru condensor it does not turn to liquid and then wont evaporate or cool in evaporator
Aug 28, 2012 | Friedrich QuietMaster SM24L30...
ONLY FAN WORKING
In a lot of Air Conditioner the fan is independent of the compressor. Some are designed like this to work both as a window fan and an Air Conditioner.
Gillight
Jun 22, 2012 | Danby Heating & Cooling
Carrier 38CKC036350 condensor fan not spinning makes humming noise compressor hot fan can be turned by hand
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | Carrier 38CKC036 Air Conditioner
Air handler turbine fan does not come on
A bad fan relay is not sending high voltage to the fan. A defective thermostat not sending low voltage to the fan relay.
How did you check the fan to say that it works?
Sep 25, 2009 | Ruud UBHC Air Conditioner
Fan doesn't work
(BACK TRACK FROM THE FAN VOLTAGES BACK........)
May 25, 2008 | Goodman PHKJ048-1 Air Conditioner
Fan not blowing
is it the condenser fan or inside blower???
Apr 26, 2008 | Weather King 10AJA2501AH Air Conditioner
Carrier 38CKC030 Air Conditioner Logo
51 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
