Epson Stylus Photo R220 InkJet Printer Logo
Posted on Sep 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer hello my paper will not go throw it go jamed and now it will not work
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Sep 03, 2007
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1027731
Points
5636
Remove the paper - carefully examing the paper track - especially the right side to ensure there is no debris blocking. Feed in a thin piece of card. Turn off the printer Hold down service/OK/Custom btton then holding these down- switch on. If still in trouble go to www.fixyourownprinter.com
1helpful
2answers
My Epson R230x printer get paper james and not feed paper, how can I solve or repair this problem
i want to know. printer back side some gape i see. but i don't know which work do in this back side.
How to remove paper jam in that printer
1. open front door
2. remove toner cartridge
3. remove jamed paper from inside
Good luck
I always have paper jamed after i pull the paper
Hello there You can try this it good little trick.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
CLP 300 was paper jaming with in first 2 inches, claened rollers and is now jaming in top of machine. have tried changing paper no effect
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
2answers
2helpful
2answers
Error Code #380
check in back side of printer there should be small paper jam check it.
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Pixma mp750
it seems the lever for the paper jam is having problem you have to open the printer and check for any broken or dislodge part.
Paper jam
problem with teflon sheat and pressor roller.Please replace the boath items.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
