Question about Konica Minolta Di1610 Copier
Minolta di1610 error message
I am getting an error message, Service call, but I have just had it serviced by minolta South Africa, and have intalled brand new toner cart.
Can anyone help
Thx
Posted by neville1 on
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
What error message? Does itsay toner cartragie need replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 25, 2009
Service center of minolta di1610 in philippines
What is the problem with the machine?
Oct 01, 2014 | Konica Minolta Minolta DI1610FP...
Minolta Di1610 error message - change t/c??? incorrect t/c type??? What to do???
Google it just as you typed it out the manufactures web page will explain better than we can
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_c7b5aba9012a13b2
Aug 26, 2014 | Konica Minolta Office Equipment & Supplies
Error c2558 develop ineo 164
need a developer Dv-116 or try to -menu quick setting << quick setting <> (service mode) go to function and press auto TCR adjust press ok or need developer Dv-116
Jul 04, 2014 | Konica Minolta Di1610 Copier
Konica Minolta Magicolor II
WOW. now that is a LEGACY Minolta Machine, Konica Minolta web site does not even list that machine try this site for a service manual
Service manuals electronic components datasheets and equipment schematics...
Feb 17, 2014 | Konica Minolta Magicolor 4690MF...
We have an error - C0210
k Normal 0 false false false MicrosoftInternetExplorer4 Transfer roller voltage problem
Jun 08, 2010 | Konica Minolta Di1610 Copier
I have di1610 wont at all error ligth are flashing
Description
Machine may cycle ON/OFF repeatedly (keeps rebooting), will not power ON (no boot-up), no message on the operation panel, LCD displays extraneous
characters and/or error code C14A3 (C-14A3).
Solution
CAUSE: The PCL board draws too much current, causing PWB-P to fail. There is no problem with GDI versions of the machine; only machines with PCL
boards are affected.
SOLUTION: The PCL board has been modified to limit current draw. If the symptoms described above occur, replace both the PCL and PWB-P boards.
Note : The new-style PCL board can be identified by a yellow sticker. Machines that had the new-style board installed during production have a yellow
sticker near the serial number plate.
may want a service technician to check the PCL boards as above
Aug 04, 2009 | Minolta Office Equipment & Supplies
Machine trouble
Sir,
To clear the fuser error code, perform the following:
1. Power the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON. Release STOP after 5 seconds.
Jul 16, 2009 | Konica Minolta Di1610 Copier
IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Feb 25, 2009 | Konica Minolta Di1610 Copier
How do I input ip address in Minolta DI1610
press the Utility/Counter -> Network Settings -> IP address
Feb 09, 2009 | Konica Minolta Di1610 Copier
Help! i get the "Machine Trouble" error
are you sure thats the right trouble code? reboot machine holding down the STOP button. this may reset this error
Dec 04, 2007 | Konica Minolta Di1610 Copier
Konica Minolta Di1610 Copier Logo
251 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
