Question about Roland Juno-D
How do i set my juno d i for a hammond b3 organ sound
Manual for aurora hammond organ it was new in 1972
Hello Linda Crum,
Notwithstanding for my GREAT admiration for AURORAs
(et al)... Like Colorado
That does NOT seem to be the way HAMMOND
Models are listed.. "AURORA" does not work...!!
I am posting a page from MANUALSLIB...
which give a physical description of
SEVERAL HAMMOND organ models...
.Hammond RT 3 Owner Playing Manual Page 7
Please see their PHYSICAL DESCRIPTION...
and look for your model in this HAMMOND manual.
Carnac the Magnificent
Mar 27, 2018 | Hammond Music
Looking for a manual for my hammond organ 124XL
I have a Hammond Fun Folio Series 124 XL. It's in good shape
Feb 16, 2012 | Music
Need a manual for old hammond organ model 122126 romance model or 1977 or 1978
You might try the ORGANFORUM.com as there are a lot of organ players there and quite a few with Hammonds. Finding an original copy is probably out of the question, but a duplication probably can be found.
Jul 15, 2011 | Hal Leonard Classic Hammond Organ Know the...
I purchased a used Hammond Organ Aurora, Model 700, 710 C125 but the previous owner did not have the manual for it. I am looking for a manual so I know how and what to do to play it. I don't know what...
Try the organforum . com. There are a lot of Hammond people there. The model 700 is the base model and probably enough to get you started.
Also just get a organ music book as a lot of the vernacular is in those. Also check your library for organ books. OFTEN the user manuals aren't much use to learn the instrument.
Most organs will either have tabs or drawbars. These select the type of "voice" and often one selects more than one as a mix. Each keyboard is refered to as a "Manual". Most organs have foot pedals. Each of the manuals and the foot pedals will have a seperate set of tabs associated with them.
To get started, turn on the organ and press the expression pedal which controls the volume... experiment setting a few tabs or drawbars an play notes on the manuals. You will soon learn what controls what.
Note that some models of Hammond organs used rotating tone wheels and those require lubrication. Those that do, usually have a power switch labelled "start" and "Run". These organs are usually higher value and one should have them serviced before using.
Nov 23, 2010 | Music
SPEAKER FOR LESLIE CABINET,HAMMOND B3,WHICH WIRE IS POS AND NEG AT SPEAKER
Here is the best source of thee info you need:http://theatreorgans.com/hammond/faq/mystery/mystery.html Take time to read the entire thing as there is plenty of good info.
Oct 18, 2010 | JBL Music
Hammond organ, L series brought out of lomg term storage problem
Lubricate with OFFICIAL Hammond oil immediately! Then let sit for a couple weeks. Manually turn the generator and add lube as needed until free. If bearings still sticky, put a bit of CRC226 on them individually and free them, then lube with the hammond oil via the wicks.
CRC226 is available at Home Depot in electrical dept.
Also, go to the organforum.com for additional help.
Jan 24, 2010 | Music
Manual hammond organ xj100
my keyboard on the xj-100 has no sound everything else does
Jan 17, 2009 | Music
Roland Juno-D Logo
82 people viewed this question
Top Roland Music Experts
Marvin
Marvin
Vernon Taylor
Are you a Roland Music Expert? Answer questions, earn points and help others
