Hi i have a casio TE-100 and for some reason if 4 example a customer spends £8.25 and gives me a £20 note wen i punch in £20 cash the till is not telling me how much change to give it is just showing spent amount on display £8.25 and i am then having to calculate correct change to be given in my head, it's a nightmare how can i resolve the problem...
cheers T..
Hi.
You need to press SUBTOTAL before you type the amount received. Are you doing this?
Mark
Ok. It is usually caused by incorrect programming during department changes.
try this for a start:
turn key to Program mode.
0
CASH
SUBTOTAL
SUBTOTAL
0
CASH
SUBTOTAL
That is unusual. Most Casios will let you remove presets on the CASH button. make sure you have finished in REG mode before turning the key, as that can cause it (try a no sale operation before turning the key). Otherwise, just turn to prog and do the second part (starting with 3 SUBTOTAL)
Sweet. You had accidentally changed the flag settings of the CASH button to stop displaying change.
yes all my staff are pressing sub total b4 the cash button, problem only recently began. Tray
Hello again, thanx 4 that, but had no joy, turned key to prog, then punched in 0 then cash and till would not allow subtotal to be entered.
any more ideas ??
Cheers Tray.
The problem now seems to be resolved, i did as u suggested and punched in 3-subtotal etc and it's been ok ever since.
Thank u 4 ur advice, u've been a great help, cheers, all the best. Tray..
