I would reset the Photo conductor unit. It will have a Green drum in it. I would make sure it is set in the machine all the way, and that the drum door opens completly. BLANK copies are and indication the paper has NOT touched the drum to recieve an image.
Well reset and remove and reinstall are the same thing. Is there a small door covering the green drum?
Ensure that the door opens as you close the covers of the machine.
Ensure (without touching the drum) that the door covering the drum moves freely and opens completely, as the door gears can slip, causeing the door to bind or not completely open hence an image cannot get transfered to the paper.
Wish I could have been of more asssitance!
Yes, I removed the jam.
warnerherbs
No.
warnerherbs
I have unplugged it and still nothing. No it won't copy either.
warnerherbs
It does everything just gives me a blank sheet of paper, and yes I have a sheet for it to read.
warnerherbs
I have removed and replaced the conductor. How do I reset it?
yes
I saw the green drum all the way to closing the door.
And Thanks for your time!
Does it scan? Does ANYTHING Happen?
Have you tried Turning off the MAIN power? So I am to assume by your post that the machine will COPY just Not PRINT?
Does it still indicate the jam is present?
Did you Clear/Remove the JAM?
How do I change the cartridge on a mf 4700 copier
