Infinity BASSLINK Car Subwoofer Logo
Question about Infinity BASSLINK Car Subwoofer
Infinity basslink sub flutters when turned on then nothing
5 Related Answers
Anonymous
  • 199 Answers
SOURCE: No Sound from Basslink
Do you have speaker wiring or RCA's hooked up from AMP to Basslink? Also check the settings, make sure you are have bridged the channels on amp.
Posted on Feb 13, 2008
Anonymous
  • 199 Answers
SOURCE: Infinity basslink is messed-up
You may have blown the fuse in the AMP. Check it and let me know.
zzedly
Tygh Duval
  • 300 Answers
SOURCE: Infinity Basslink killing battery
Both issues sound like they are related to a non-connected or loosely connected remote wire on the Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
Posted on Mar 20, 2008
Anonymous
Thanks for the reply. I took the sub to Best Buy and had the guy look at it - not surprisingly, I couldn't replicate the problem once I was there. It was working fine at that point and he thought maybe the sub got a little too hot and just shut down on its own. It's been fine since then, so hopefully that was it. Still, for others the voice coil may have blown so good to know that could be it as well.
Posted on Oct 17, 2008
Anonymous
  • 655 Answers
SOURCE: is the light on the infinity basslink suppose to
Hello jmw3031,
The Basslink should have both a red power LED and a green servo LED. The red LED should be on when power is applied. The green servo LED should only come on during high-level bass transients. Turn the gain down slightly if it stays on for extended periods.
Hope this helps.
Posted on Jul 15, 2009
I have a 2005 Mitsubishi Eclipse with the Infinity high end stock radio installed, which has a 200 watt amp under the seats. The head unit does does not have direct speaker outputs. The head is connected...
I am going to refer you to the live help
at crutcfield.com audio
They can give you ideas on compatible equipment and designs that will achieve your desires without the OBVIOUS overlad/mismatch.
Your search for comparison returned these articles
Free factory (usa market) wiring diagrams
BBB Industries Premium Alternators Starters Power Steering Products
Where to purchase vertical mounting feet & bolts for Infinity sub
Simple as it sounds, try Home Depot/Lowe's! They will have them! Been there, done that!
I need the wires to conect my infinity basslink 10''
Any auto parts store or WalMart will sell adequate speaker wires. For a sub of this power rating, you'll be fine with 14GA speaker wires (pronounced 14 gauge) but if you want to get beefier wires in case you upgrade the sub later, I'd recommend this 10GA hookup kit or something comparable.
My sub woofer wont turn back on
Hello austin_optiz,
If you have had 2 units with the same problem, I'd say that yes, there is a problem with the "sound sensing" function of the auto turn-on circuit. Either it's not getting the correct level or one side is being shorted or grounded. Some vehicle speakers may have one side at ground potential which could cause the auto turn-on to fail.
If the Basslink operates normally otherwise, I'd recommend that you just connect a 12V + fused and switched source to the remote terminal. Wire it through a conveniently mounted toggle switch and turn it on and off manually.
Hope this helps.
Phntom bass sounds
uhhh....try you change your wire setup
2answers
Infinity Basslink
That popping you hear is most likely the voice coil blown and your not going to get much out of it now. Discontinue use of the unit so it doesn't blow the amp, and you can get the sub replaced if you don't want to toss it.
Good luck, hope this helps
2nd Basslink, still no power-on. Please help
this is in response to the post below:
I just bot a basslink t and i wired it up and nothing it just keeps blowing the fues in the unit i got mine on ebay2.gif so i dont know if i can use the warranty dose anybody have an ida for me- britter623
I got a used basslink about a month ago and had the exact same prob kept blowing fuses...found out that the voice coil had blown on the infinity...so I had a brand new dvc polk 10 sittin in the closet, I swapped them out, put the polk in the place of the infinity sub, however, the magnet is much larger, hence, dual voice coil, it would rattle sooo much from the passive radiator against the magnet, also could not turn the gain up at all due to the rattle. I got the bright idea to build a "custom fiberglas enclosure for the polk and incorporate the infinity's parts(amp/control) I finished the box finally last night and hooked it up this morning, no power, no lights, no nothing! [email protected]#%, F&@%! ANyone had a prob w/the amp not having the lights turn on, no power??? Hope that helps about your fuse blowing issue.
1helpful
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Morne Olivier
Morne Olivier
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
