I was able to hotsync my LD once with my PC. the next time i tried it, i couldn't connect with my PC anymore. the lifedrive manager window would be on and indicate the space i have available on the lower right corner. when i press the hotsync button on the cable attached to the base of the LD, the lower right corner changes to a message; "palmOne device is not connected". then i get a similar message on the LD saying i'm unable to hotsync. when i tap "ok", the lifedrive manager reconnects on its own telling me whats in my device and space available. same thing happens when i tap the hotsync button in my LD
I've had this problem getting these set up in the past for customers.
What you want to do is go to your device manager and sync the palm while the window is open.
Look for a yellow triangle with an ! in the middle of it down towards the bottom by USB controllers.
If it pops up, double click on it and go to the drivers and try to reinstall your driver.
Posted on Jan 07, 2008
If u need to make connectivity between computer and Palm mobie then u need to install hot sync software on ur Pc and activate hotsync option from ur mobile then with cable u can transfer the data . if u not have proper software of hotsync then download it from palm Site.
Gizmo1
