Question about Honeywell HHT-145 Air Purifier
No operating instructions in Honeywell HHT-145 air purifier box
There were no operating instructions or warranty in the box of the Honeywell HHT-145 air purifier. Can I find one online? Thank you
Posted by misita on
  • Steve Allison
    Steve Allison May 11, 2010
    No clarification, just commentary-
    After checking a number of sites for a user guide/manual for your unit, I have not found one for your unit and Honeywell's site is one of the most useless I have seen for support purposes.
    I would be steaming mad if I bought a supposedly new unit with the documentation missing.
    If you do find a manual on line, it would be helpful if you would upload it to FixYa one of several other sites offering manuals such as Retrevo and Safemanuals.
Anonymous
Http://www.kaz-canada.com/kaz/support/manual/#Honeywell
All honeywell manuals are on this site
Posted on Mar 21, 2010
Anonymous
I need an owner's manual for Honeywell Air Purifier HHT-082-TGT and cannot find it on the Honeywell Instruction Manual website
Hello, this is Ava with Think Crucial.
You may find you online instructional manual for your Honeywell model by clicking the link below.
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/hht080hht100.html
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 12, 2015 | Honeywell Pet Cleanair Air Purifier...
No power
mine was having the same issue. its been broken for 2 years now. i jsut fixed it a few minutes ago. there is a button sensor behind the top filter. if its not pushed in all the way it wont turn on. my filter was in correctly, but the button doesnt appear to be depressed all the way. when fastening the back cover it locked in good, but was still slightly loose. those two things together means the sensor wasnt being triggered.
with your unit correctly assembled plug it in. while plugged in simply press the top of the back cover (where that sensor is) and the light should go green. i then taped it tight with a thin electrical tape as to not limit the airflow. it now powers on and works great.
hope that solves it for you
Mar 08, 2012 | Honeywell HHT-145 Air Purifier
Gentlemen: The LCD display on top of the purifier indicated that the filters were dirty. We removed the 2 filters, vacuumed both sides and reinserted them. We are still getting an indication that the...
According to what I found, if the filter is not reinstalled just right, it won't trigger the filter being back inplace switch.Also, try unplugging the unit for 30 minutes and then plug it back in. That may reset the switch. If tall else fails, call Honeywell Customer Service at 877- 841-2840.
Hope this helps to solve the problem, JR.
Mar 07, 2011 | Honeywell HHT-145 Air Purifier
Honeywell HHT-011 Air Purifier red light will not turn off even after cleaning the filter three times.
For those who's red light will not turn off after cleaning. There is a little button by the red light indicator. Take a paper clip and hold in for about 5 seconds. Light will then turn off.
Jan 22, 2011 | Honeywell HHT-011 Air Purifier
Honeywell htt 011 air filter light won't go off
Thank you to MPODHOLA. After cleaning your Honeywell HHT-011, if the red light does not turn off locate the very small button under the red light. As suggested use a paperclip, hold the button for 5 seconds and this resets the system. Make sure the unit is on when you hold down the button. I tried it with the unit off and it did not work. Turned on the unit, held down the button for 5 seconds and the system reset. No more red light.
Dec 03, 2010 | Honeywell HHT-011 Air Purifier
Can you tell me the difference between the Honeywell Tower Air Purifier HHT-081 and HHT-090? From what I find, they seem identical.
I am 99.9% sure that you are simply looking at this year vs. last year models. There are absoutly no significant changes. I will verify on Mondayas I know the engineer at Honeywell that works on this particular product!
Jan 29, 2009 | Honeywell HHT-090 Air Purifier
After cleaning and replacing filters, won't turn on
I have had the same problem. The way I fix mine (it only runs for a couple days staight) is to switch the two filters (or maybe you just need to remove completely?) making sure they are in tight. Replace the cover and it should work!
Sep 06, 2008 | Honeywell HHT-145 Air Purifier
Honeywell HHT-145 Air Purifier Logo
1,346 people viewed this question
Top Honeywell Air Purifiers Experts
jdthefixer
Muntejaya Ginting
Muntejaya Ginting
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
