Question about Yamaha Electrical Supplies
Coil gap for Yamaha Generator. Homelite HG5700 series
1 Related Answer
Sheldon Dedek
  • 912 Answers
SOURCE: Yamaha 5700 homelite generator stopped
Hello Karen,
What you are describing is not good at all.
There are 3 things that can cause what you said.
1) The engine seized due to lack of oil, though this generator should have a low oil shutdown, it may have failed, especially if the generator was being operated off level.
2) The engine has over heated, to the point that it seized.
3) A mechanical failure in the alternator, perhaps a bad bearing, has created a large amount of drag on the engine.
Would you check the oil, and post back where it sits at? Might have other options.
Posted on Sep 23, 2010
Homelite easytrim ignition coil gap
First unplug your spark plug. Take off the engine shroud (cover) and expose the flywheel. Loosen your coil. Put a paper business card (roughly .10" "- .11") between the two legs of the coil and the magnetic spot on the flywheel. Let the magnet on the flywheel pull the coil to itself WITH the business card between. Make sure you get the card between both legs of the coil. Snug 'er down and rotate the flywheel to release the card. That's your clearance.
Jul 17, 2018 | Homelite Garden
Generator PM0601100, Sparks are very weak, machine doesn't start
That generator has a 20HP Honda engine. If the magneto on the engine is bad then the spark level is low. To check this you need to take the cover off the engine on the side away from the generator. There should be a flywheel with a magnet built in and there is a coil that the magnet passes by. Check the gap between the coil and the magnet. IT should be very close to each other. Honda says the gap is between .008 and .016 inch depending on the model of the engine. If the gap is ok then you need to check the coil connections and resistance with a meter.
Sep 12, 2015 | Electrical Supplies
I have homelite textorn 7500watt generator not strating ,no carunt to spark plug
You'll need to look up to see what the ohms are on the coil of that chainsaw use of a multimeter required it should have a reading between to set readings if ok then check for loose or broken wires
Feb 07, 2015 | Homelite Garden
What needs replaced if I have no spark
Coil, points, spark plug, shorted switch, or the switch being left on the stop mode
Jul 26, 2014 | Yamaha EF3000iSEB Generator 3000 Watt...
Install coil on homelite ut10518
Hi Hiram, 8 thou is the correct gap. Regards Phil.
Aug 30, 2012 | Homelite Ut10517 - 18"
Ignition coil air gap
If you have a new coil check for a gapping card in the part box. Otherwise the gap is usually achieved with a business card thickness of paper! I used to use the box tops of the parts boxes as my gapper. True story! You will probably see the spot where the old coil made marks on the engine *(clean vs rusted) to confirm you are in the right ball park. Be safe and good luck!
May 30, 2012 | Homelite Garden
Need coil mag air gap for homelite model ut20006 line tremer
You can set the air gap for the coil with a business card used as a thickness guage.
Sep 06, 2011 | Garden
Yg2800i generator runs for about 5 minutes and then stalls
Put a new fuel filter on it and when it stalls take the fuel line off the carburetor to check if gas is getting to the carburetor. If it is remove the sparkplug put the wire on it and ground the nut of the plug on the engine block and pull the cord and check for spark between the sparkplug gap. If no spark you might have a faulty coil, when it gets hot it has no spark.
Mar 20, 2011 | Yamaha 2500 Watt Industrial Inverter...
I need the gap setting for the coil on my homelite weedeater 25CC 'Easy Reach'
As small as you can without fouling the flywheel. It should work with anything up to a 20 thou gap, so if you set it to 10 thou and no spark, then you need to replace the coil..
Sep 08, 2009 | Homelite Garden
I can not get a spark on my dominator ,checked the kill switch pulse generator ,new coil new plug ,
Did you replace the plug wires? are the spark plugs fouled or gapped improperly? Check to see if you have power going into the coil, if you do then there should be spark coming out of the coil, and if there is and your wires and plugs are proper and servicable then you should have ignition.
Jun 07, 2009 | 1997 Yamaha XJR 400
Electrical Supplies Logo
126 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
