Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
Toshiba TW65X81, picture is good except for a snowy static that flutters on screen. Help!
Posted by Leo Sawin on
My tv only displays snowy screen with load static noise. When I unplug it and plug it in the tv turns on by itself and the snowy screen and load static are there.
check that the antenna wire is properly connected as the screen indicates that it is not working or connected properly
Jan 03, 2016 | Televison & Video
Tv picking up channels except its all static, colorless, and loud static noise..
If the set was purchased in the USA it has the USA format which is NTSC--unless the signal is NTSC picture will be in black and white and no sound.
If the signal format there is PAL OR SECAM you will need a converter that takes that and outputs NTSC for the set to work properly there.
May 16, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
The picture is wavey and color is blurry
Convergence problem....$300-$500 repair. This TV is a great unit,
Jun 01, 2011 | Toshiba TW65X81 65" Rear Projection...
No picture in a picture
The picture for picture-in-a-picture must come from somewhere. Try a DVD for the picture in picture. It may be the second tuner for the picture in picture that has failed.
Mar 30, 2010 | Hitachi 50UX26B/27K 50" Rear Projection...
Need to clean mirrors on Toshiba TW65X81.
I need to take the tv apart to move from upstairs to downstairs
Dec 16, 2009 | Toshiba TW65X81 65" Rear Projection...
Screen is nothing but static, BUT...
cheak your cables what inopuut is snowy all or just tv does dvd work
Feb 03, 2008 | Tatung V27DMBX 27 in. LCD Television
Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Nov 21, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Snowy picture
A snowy video indicates that your input signal is relatively weak. On the other hand, a noisy picture is when there are too much interference is super imposing on the video.
Snowy picture comes about when the signal coming in the RF INput (Ant/Cable) at the back of the unit is below a certain level. If this is the case, then it is not a problem with your TV but rather your aerial (antenna) or the cable from your provider. A way to verify that it is the ant/cable that is the cause and not a defective TV/tuner is to hook up an old VCR set to Ch. 3 or 4 to the RF IN of your TV using a short 75 ohms coaxial cable terminated at both ends with FP-5 connector. Play a known clear good tape and set your TV to Ch. 3 or 4 as the case maybe. If the picture is relatively clearer, better, then you have just confirmed that it is indeed your aerial or your cable (provider) that needs looking into. If on the other hand, the VCR signal is also snowy then chances are that you have a problem with the input stage of your TV including possibly your tuner.
For your aerial problem, antenna orientation or replacing with a higher gain antenna might help solve the snowy signal. For your cable problem, you have to call-in for service from your cable provider. If it is a TV problem, your best course would be to seek the services of a qualified TV technician since this involve electronic circuitry analysis, diagnosis and possible component replacements.
Additionally, you may try looking for any loose connection, loose grounding, broken wire or anything out of the ordinary in your connections.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 12, 2007 | RCA P52926 52" Rear Projection Television
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
